gazamataz
Advice please, best RouterBoard for site to site SSTP VPN
Sun Dec 21, 2014 5:12 pm
I'm looking to purchase two RouterBoards so I can set up a site-to-site VPN using SSTP.
Does anyone have any recommendations as to which RouterBoard model would be most suited?
Basically I'm setting up a remote office in Budapest and discovered the standard VPN ports are being shaped by the ISP, so planning on using SSTP VPN via standard SSL port. I read the newer RouterOS does not need certificates for SSTP VPN, which sounds quite convenient.
Ideally if the RouterBoard on the Budapest end had wifi as well, the main site RouterBoard in the UK doesn't need wifi.
Not sure if it's relevant but it will be a fairly small office in Budapest, a couple of computers, a couple of VOIP phones, couple of IP security cameras and probably a Roku or similar gadget to access on demand TV.
Thanks for your help!
Gary.
garlicbulb
Re: Advice please, best RouterBoard for site to site SSTP VP
Wed Dec 24, 2014 6:05 am
Selection of the router would be based on what throughput and number of ports. Any router with license level 4 should suffice
For small offices, I have been using the RB951Ui-2HnD and an external switch
bkuhn
Sat Dec 27, 2014 12:53 am
I'm a fan of the RB2011 hardware. I have several of these deployed RB2011UiAS2HnDI running site-to-site IPSEC VPNs.
That model has wireless included, there is another variation of the same case/routerboard without wireless.
docmarius
Sat Dec 27, 2014 2:11 pm
I would really take a look at the RB850Gx2, since it has hardware encryption support and a faster CPU.
If you need/want rack mounted hardware, a RB100AHx2 or CCR1009-8G-1S are great candidates, but in another price class.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
w0lt
Sat Dec 27, 2014 2:57 pm
Couldn't agree more.. Both of those devices work great for IPSec links !!
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
MikroGik
Sat Dec 27, 2014 6:15 pm
@bkuhn -
How many concurrent site-to-site IPSec tunnels, would you guess, the RB2011 can handle?
I must plan ahead for at least 25-30 concurrent L2TP/IPSec tunnels and I'm trying to pick the right MikroTik hardware for that.
I already have a RB2011, but wondering if I need do move up to the new RB850GX2...
Thx
Jeroen1000
Sun Dec 28, 2014 12:11 am
Except that the 850Gx2 does NOT have hardware encryption. It's for a later model revision. I got fooled too but it's fast enough for my 10 megabit upload connection:))
reeja
Thu Jan 01, 2015 7:16 am
with integrated Wlan card disabled power consumption will be approximately the same.
You can easily check out our best quality vce converter exam dumps
Users browsing this forum: No registered users and 16 guests
