Lakis
Forum Veteran
Forum Veteran
Any plans for GBit PoE out ethernet router
Sun Jan 11, 2015 11:20 pm
Any plans for GBit PoE out ethernet router and when?
normis
Re: Any plans for GBit PoE out ethernet router
Mon Jan 12, 2015 10:58 am
We always have ideas, but we don't disclose them until there is something substantial to announce.
Thank you for the suggestions.
Petzl
Mon Jan 12, 2015 7:50 pm
CRS-110 8G S 2HnD will have this option i think
see internal pictures of the CRS-109 where the PCB is labeled CRS-110 and there also POE out connector
https://drive.google.com/folderview?id= ... sp=sharing
Quindor
Mon Jan 12, 2015 8:26 pm
Having POE out on an 8 port Gigabit switch/router with WiFi and no 10Gbps uplink capability does not make too much sense to me.
I would much rather see they would introduce an 8 or 12 port switch (CRS) with SFP+ to be able to uplink it with 2x10Gbit (Cheap DAC cables stack). That way we could feed our Camera's, Access-Points, small end switches and Phones in homes and small business installations. Now a days with AC capable routers a switch with multiple devices connected to it needs more then a 1Gbps uplink.
That said, to support the most broad range of equipment it would need to support 12v, 24v and 48v POE and passive mode. Not a small thing to get right, but if Routerboard does, it will be a sure seller. Currently we need to use Ubiquiti devices to most of this. :(
honzam
Mon Jan 12, 2015 9:37 pm
+1. We need such product
bajodel
Long time Member
Long time Member
Tue Jan 13, 2015 7:25 am
maybe with hardware driven spanning tree
+1
Lakis
Forum Veteran
Forum Veteran
Sun Jan 18, 2015 9:28 pm
So are there any chances for some announcements in the near future? I believe that by now you should have had such products.
nz_monkey
Mon Jan 19, 2015 1:00 am
We are wanting such a product as well.
CRS with support for 802.3af/at PoE out.
Users browsing this forum: No registered users and 29 guests
