solelunauno
SXT system health voltage
Wed Jan 21, 2015 8:38 pm
What's this? 79V?
My RBSXTG-5HPnD-SAr2 with 6.24 show this strange /system/health value.
With 6.1 (default) they show 124V and with 6.18 they show 11.9V and 23°C that is something correct.
I made "upgrade firmware" after system upgrade, obviously.
How can I solve?
SL1 Systems srl MTCNA MTCRE
shahbazian
Trainer
Trainer
Re: SXT system health voltage
Thu Jan 22, 2015 1:05 am
Do you upgrade the RouterBoot too?
If you have not upgrading RouterBoot after RouterOS upgrade, run this command:
/system routerboard upgrade
and then reboot your router.
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
Sob
Thu Jan 22, 2015 2:04 am
And that was your mistake ;), see 6.23 - system health - is not working properly.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
solelunauno
Thu Jan 22, 2015 2:25 pm
I upgraded the RouterBoot and now it's 3.19, so Sob is right and it isn't really my mistake, but something wrong with routerboot 3.19. I'll downgrade where I need it. Thanks.
uldis
Fri Jan 23, 2015 2:46 pm
we were able to reproduce this and will make a fix in the next RouteBoard firmware.
Users browsing this forum: No registered users and 10 guests
