lkthomas
951G-2HnD too slow for 1Gbps connection?
Mon Jan 26, 2015 6:55 pm
I just got my first RouterBoard which is 951G-2HnD, did some testing and max sped is 300Mbps; Is this board too slow for 1Gbps connection? or there is some misconfiguration I have done on this board?
normis
Re: 951G-2HnD too slow for 1Gbps connection?
Tue Jan 27, 2015 2:59 pm
how did you do the test? single TCP connection will always show lower number than multiple UDP connections (like torrent).
but please note that this is one of the lowest cost APs we have and is meant for moderate home use. 300-400Mbit is what you could expect with standard config.
Quindor
Tue Jan 27, 2015 6:15 pm
What exactly are you trying to do?
Switching, routing or NAT?
Switching it should do full 1Gbps Full-Duplex on all ports, routing 500Mbit ish and with NAT 250-300Mbps. So if you are talking about a 1Gbps internet connection which requires NAT for instance, no, you have the wrong model for your situation.
Please please explain you usage case a bit better so we might be able to figure out if you actually have a problem with the device or configuration. :)
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
lkthomas
Wed Jan 28, 2015 1:37 pm
I am running simple broadband NAT, my goal is to reach 1Gbps for NAT routing, looks like I bought wrong model to do NAT routing.
And yes, I could only reach 300Mbps max and at that traffic, CPU jump up 100%!
lkthomas
Wed Jan 28, 2015 1:40 pm
for benchmark, I use http://www.speedtest.net to do testing.
normis
Wed Jan 28, 2015 4:11 pm
Something like this is more suited to get such speed for NAT routing Gigabit speeds http://routerboard.com/CCR1009-8G-1S
The RB1100 also, but they are both rackmountable units. We will soon start shipping CCR1009 core in a smaller, silent case (the -PC model). Maybe this one you will like.
lkthomas
Wed Jan 28, 2015 4:45 pm
Problem is that I am using 1Gbps broadband at home, doesn't make sense to spend 425USD just for a router which could route 1Gbps NAT traffic, I believe I could get something like TP-Link at half of the price (or less)
normis
Wed Jan 28, 2015 4:48 pm
In this case, NAT routing speed will be even much lower.
I personally use Switch mode for my main computer, to get real IP address, and use only the other ports for LAN. This way, you will get full 1Gb for one device, and rest can be routed or what you wish
jarda
Wed Jan 28, 2015 6:32 pm
Some cheap tp links have hardware accelerated nat so they are able to provide more than 900Mbps thru it. But they are missing everything else that mikrotik offers. If you need real router with custom set of rules, you will fall into cpu processing even with hw nat. So you can buy bad and cheap nat or good but not so cheap router. Go for 1100ahx2 and you will be happy. Suggestion by normis is not a way as you wouldn't like to expose your home computer to public Internet, I guess.
honzam
Wed Jan 28, 2015 8:49 pm
+1
Add hardware NAT for you new routers. For example - DualBand routerboard like rb951G, rb2011, etc...
LAN, FTTx, Wireless. ISP operator
jarda
Wed Jan 28, 2015 9:09 pm
What does it mean? There are not such dual band devices... (Actually, only Groove52 is dual band, all others are single band only, unfortunatelly). Better than dual band would be double radio with dual band possibilities for both radios.
But anyway hardware assisted NAT without full feature possibilities that ROS offers would not be so great thing because everyone uses some settings that would prevent the hardware accellerator to work. But, if it could be without any impact on price, Let it Be!
honzam
Wed Jan 28, 2015 10:00 pm
I thing future products.... Now has no RouterBOARD hardware NAT?
It would be nice include hardware NAT in future products...
InoX
Wed Jan 28, 2015 10:59 pm
The problem is that mikrotik team don't want to implement hardware NAT since a simple router like TL-WDR3600 that uses AR9344 has hardware NAT but no mikrotik product with the same cpu has this feature. And there are a lot of RB's with this cpu.
Or maybe they lack the know-how.
normis
Thu Jan 29, 2015 9:37 am
Generally these other brand devices have limits on number of connections, when you exceed some 1000 connections or so, everything stops working or becomes very slow. We are certainly researching hardware accelerated NAT, but I just wanted to clarify the potential implications of this technology.
Raf
Thu Jan 29, 2015 11:40 am
HNAT isn't located in CPU InoX. Actually it is located in Atheros switch chip. MikroTIk uses model AR8327 and TP-LINK (and others also) uses AR8327N model. Notice the last letter N in model name. It stands for Hardware NAT feature built-in. I was e-mailing MikroTik support long time ago about this chip but maybe Normis is right about all downsides of this feature.
Rafał Wójcik from AWB-NET
High Definition enthusiast
InoX
Thu Jan 29, 2015 1:25 pm
Didn't know that but it will be very interesting to implement hardware NAT at least in dual core routers. Indeed tplink routers needs reset from time to time for the hnat to work, a lot of people are complaining on forums. In Romania almost all providers ofers speeds from 200mbps on cable tv to 1Gbps on fiber (for under 20$/month) so there is an real need for HNAT.
peper
Sat Feb 07, 2015 10:38 pm
1 Gbit cost $20/month in Romania? Cool! You must have a highest average internet connection speeds in the world! Or "offers" doesn't mean a lot of customers buy it?
InoX
Sat Feb 07, 2015 11:38 pm
In fact :
1Gbps - 14.25$
100mbps - 7.5$
Many of us still have 100mbps connections. Is more than enough for normal people.
barkas
AW: 951G-2HnD too slow for 1Gbps connection?
Sun Feb 08, 2015 2:52 am
A ubiquiti edgerouter will nicely do 1g with an OK feature set.
Spaham
Mon Feb 09, 2015 11:17 pm
Hmm how soon ? :)
I purchased a RB2011UiAS-2HnD-IN and unfortunately it is way too "small" for my fiber gigabit connexion :(
I wish you'd sell a CCR1009 that supports wifi AP as well !
A lot of people here (in france) have now access to gigabit fiber for around 30€/month, so this IS becoming a real market !
thanks
normis
Tue Feb 10, 2015 8:20 am
how soon? it is already shipping: http://routerboard.com/CCR1009-8G-1S-1SplusPC
peper
Wed Feb 11, 2015 1:52 am
Cool! Can you do the same trick with wall/ceiling mountable AC access point? ;)
honzam
Wed Feb 11, 2015 9:11 am
peper
Wed Feb 11, 2015 12:49 pm
Well, I mean retail ready to run product, not do it yourself. :)
honzam
Wed Feb 11, 2015 12:51 pm
Still waiting.... :) Now only home made :)
Users browsing this forum: No registered users and 19 guests
