Hi all
I want to create a wireless solution for a small 4 floor building (+-100 users max) in the city (a.k.a 2.4ghz band is congested).
I am required to make a dual band solution, using the BaseBox 2 and an R11e-5HnD (or R11e-5HacD).
The antenna's I want to use are normal Omnidirectional antenna's directly connected to the BaseBox.
However, I've got 2 problem now:
- I've read that antenna spacing is important, but since I want to connect them directly to the Basebox it might ba a problem (2 antenna's for 2.4Ghz and 2 for 5Ghz)
- I don't know what antenna's to buy, there are cheap one's and very expensive one's and I have no idea about the quality differences or gain I should take.
Can anyone give me some advice about the most cost effective solution?
