keefe007
SFP-10G-LR Doesn't work on CRS
Tue Feb 24, 2015 8:41 pm
I have tested and discovered that SFP-10G-LR SFP+ modules don't work with the CRS226 series switches.
Keefe
ATG
Re: SFP-10G-LR Doesn't work on CRS
Wed Feb 25, 2015 10:18 am
I am currently using a SFP-10G-LR in a CRS226, linked toward a CCR. This setup has worked fine the last 6-8months.
The SFP+ is a Fiberworks module, but is Cisco coded(was originally supposed to be used in a Catalyst 4500-e switch), but works fine with all Mikrotiks I have tested it with.
Regards
krisjanis
Wed Feb 25, 2015 11:51 am
Keefe
Please post printouts from commands:
/interface ethernet print detail where name~"sfp"
and
/interface ethernet monitor (interface)
keefe007
Wed Feb 25, 2015 6:36 pm
[admin@ehq-sw1] > /interface ethernet print detail where name~"sfp"
Flags: X - disabled, R - running, S - slave
 0  S name="sfpplus1" default-name="sfp-sfpplus1" mtu=1500 l2mtu=1588 mac-address=4C:5E:0C:9B:C4:DE
      orig-mac-address=4C:5E:0C:9B:C4:DE arp=enabled auto-negotiation=no
      advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full full-duplex=yes tx-flow-control=off
      rx-flow-control=off speed=10Gbps master-port=ether1 bandwidth=unlimited/unlimited switch=switch1
      sfp-rate-select=high
 1  S name="sfpplus2-gfs-xe" default-name="sfpplus2" mtu=1500 l2mtu=1588 mac-address=4C:5E:0C:9B:C4:DF
      orig-mac-address=4C:5E:0C:9B:C4:DF arp=enabled auto-negotiation=yes
[admin@ehq-sw1] > /interface ethernet monitor sfpplus2-gfs-xe
                    status: no-link
          auto-negotiation: done
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-lose: yes
              sfp-tx-fault: no
        sfp-connector-type: LC
       sfp-link-length-9um: 10000m
           sfp-vendor-name: OEM
    sfp-vendor-part-number: SFP-10G-LR
       sfp-vendor-revision: A
         sfp-vendor-serial: CLS10281932
    sfp-manufacturing-date: 14-01-10
            sfp-wavelength: 1310nm
           sfp-temperature: 44C
        sfp-supply-voltage: 3.348V
       sfp-tx-bias-current: 0mA
              sfp-tx-power: -7dBm
Here's one side. I have to get the other in a little bit.
krisjanis
Thu Feb 26, 2015 11:33 am
In printout we can see that module for some reason ain't receiving incoming signal from device that is connected on the other side. Printout from other device could probably show more. Also please mention what device model you have on the other side of link.
Users browsing this forum: No registered users and 9 guests
