shipilev
RB951G-2HnD antenna diagram
Sat May 23, 2015 10:40 am
Where can one find the antenna power diagram for RB951G-2HnD? It would help to understand how to put the router in the particular environment. Basically something like SXT 2 has in its brochure: http://i.mt.lv/routerboard/files/sxt_2-150129090119.pdf
Googling and sifting through routerboard.com did not yield any results.
Thanks!
jarda
Sun May 31, 2015 8:22 am
I am afraid I haven't seen it but it was already told somewhere here on the forum that those antennas have almost sphere character.
chechito
Re: RB951G-2HnD antenna diagram
Mon Jun 01, 2015 5:29 am
rb 951 series has omni antennas i think a antenna patterns is not necessary
maybe max 3 or 6 dbi of difference between some spots or another's do not justify a diagram.
that diagrams are useful on sxt and even omnitik are outdoor devices for use when there are ideally no obstacles.
rb 951 devices are for indoor use normally, and in this scenarios the building and objects and obstacles on the site change the propagation patterns mostly, than any differences on omni pattern of antenna
normis
Mon Jun 01, 2015 9:31 am
the diagram is nearly spherical, so you can point it as you wish.
Users browsing this forum: No registered users and 10 guests
