timd93
hAP Lite bad wifi performance [FIXED]
Fri Jun 05, 2015 8:49 pm
Is anyone experiencing very bad wifi performance on hAP Lite?
No matter what device I use, or good my signal is, I can't get more than 20Mbit.
I've already done this command but that didn't work
interface wireless reset-configuration
honzam
Re: hAP Lite bad wifi performance
Fri Jun 05, 2015 10:42 pm
Settings? I have no problem over 90Mbit on speedtest
LAN, FTTx, Wireless. ISP operator
chechito
Sat Jun 06, 2015 8:08 am
what datarates report the client on registration table with that performance??
honzam
Sat Jun 06, 2015 8:47 am
150Mbit.
I have only 150Mbit wireless card in notebook
timd93
Sat Jun 06, 2015 4:23 pm
Well it's fixed I think, I forgot to re-enable chain 1 and 802.11n after I reset the config. I'm getting 60-80Mbit now :D
chechito
Sat Jun 06, 2015 7:06 pm
ok, take in count thats using 40mhz channel not every environment allow that 2.4 ghz its crowded in many sites
jozsi777
Re: hAP Lite bad wifi performance [FIXED]
Fri Jun 12, 2015 2:11 am
Hello, Everybody.
I bought a new MikroTik hAP lite router, but Im a beginner about the configuration.
Please I need some help to make my router work.
Can someone help me? Or give me a tutorial, which is understandable and good, because I saw some tutorials on the internet but none of them were good. I had to reset my router 'cause I misconfigured something.
normis
Fri Jun 12, 2015 10:12 am
Hello, Everybody.
The device is configured when you buy it. Just plug the cables and use it. What do you want to configure?
jozsi777
Fri Jun 12, 2015 12:37 pm
No its not working. I can only access my routers homepage to configure.
normis
Fri Jun 12, 2015 2:06 pm
Good, if you found the router webpage, you are on the right track. Now all you need to do, is enter the settings from your ISP on this page. If not sure what to enter, call the ISP
jozsi777
Fri Jun 12, 2015 4:09 pm
Fortunatelly my problem was solved, Thanks. Anyway, do you know how is it possible, that I have 50Mbit-net but over wifi with speedtest I can only mesaure 17Mbit- and with my mobile it goes up to 19Mbit-. How is it possible?
Can you help me?
Thanks.
jozsi777
Sat Jun 13, 2015 12:27 am
How is it possible, to configure to channel N? I've tried with the quick set, setting up 2Ghz only N- but after that I could not connect to the internet. I've heard that if Im using N-not G then I can get nearly 50Mbit-net not just 17 or 19. thanks
Users browsing this forum: JGA, pohutukawa and 40 guests
