shuum
MTBF of RouterBOARD
Wed Aug 05, 2015 12:18 pm
Dear customers!
Please tell me about MTBF (mean time between failures, a measure of the reliability of a device or system) for RouterBOARD hardware. Where can I get this information?
Great Thnx!
P.S. It would be great if you could send some sort of a document confirming this...
kiler129
Re: MTBF of RouterBOARD
Wed Aug 05, 2015 12:52 pm
From my knowledge MikroTik doesn't have such data (because no official tests are preformed to determine MTBF).
However from my observation you can expect around 4-5 years lifetime (for 24x7 scenario). In my opinion 3 years is a sensible rotation period due to technology evolution.
ste
Wed Aug 05, 2015 1:23 pm
This heavily depends. Some boards never die some very early. 1xx/5xx was undestroyable. 600 had weak ports. SXT tend to die earlier.
3 Years is to short. E.g. we have RB1000 we dont want to replace.
juanvi
Wed Aug 05, 2015 1:31 pm
Imho since in RB hardware there are no moving parts I will expect higher mtbf times than a mechanical HD drive.
"Hard drive manufacturers quote average hard drive life as Mean Time Between Failures (MTBF). Ordinary consumer drives are in the 500,000 hour MTBF range, while enterprise (e.g., more expensive) hard drives can range up to 1.5 million hour MTBF. Since there are 8,760 hours in a 24x7 year, 500,000 hour average MTBF is a lot of years. Right? Yeah, 57 years is the answer"
¡vʞvdnX puv ···SOɹǝʇnoɹ ʞıʇoɹʞıW oʇ sʞuvHʇ
shuum
Wed Aug 05, 2015 1:34 pm
Thnx!
I really hope to see the official comments of developers.
kristaps
Wed Aug 05, 2015 2:57 pm
We have not made any MTBF calculations for any of our devices. These calculations are purely theoretical, they do not reflect real life, so we don't provide them for our products.
djdrastic
Wed Aug 05, 2015 3:14 pm
We replace them 3-4 years tops.
After that you deal with capacitor , power supply and flash issues down the line.
ste
Wed Aug 05, 2015 4:54 pm
No. If you track the failure rate/returns of your products you will see very different numbers between your products. This is no theoretical value.
The selection of components heavily influence the live time. So you might categorize your products in "normal user" / "industrial" / "rugged/extended life time". Esp. the capacitors in outdoor devices or the selection of UV resistent plastics might be a difference.
This would give us the chance to select the right product for the use case. E.g. we give "normal" or "business grade" CPEs to our users. "Normal" is a SXT Lite. "business grade" is a Mars Antenna with metal enclosure and .ac board inside.
We see SXTs coming back with popped up Ethernetport or some dont boot anymore. Some drop the wireless connection from time to time. The plastic moves to yellow after a short time in the sun. So this is the cheap line. This is normal. We buy a cheap CPE so we get cheaper components. But when a user/we want to spend more money to get a more rugged device we need an indicator what board/device to buy. At the moment we talk to the distributor to get an idea ...
shuum
Wed Aug 05, 2015 5:33 pm
:o Strongly disagree! This is the most important characteristic! This allows you to determine the degree of reliability and applicability to large and serious projects.
doush
Long time Member
Long time Member
Fri Aug 14, 2015 5:58 pm
I remember RB100 and 500 series. Some of them still in use after 5 years of time.
Newer products tend to fail earlier than that.
I wish we could find the same stability with the new products compared to the old series.
Petzl
Sat Aug 15, 2015 1:21 am
We always use meanwell power supply's with batt pack
in 10 jears time on a network with 5000 wireless devies and 800 mikrotiks and we had like 12 mikrotiks broken for no reason. , at the moment we use mikrotik for routing, 87% of the wireless hardware is from a other brand.
and +- 40 mikrotiks did go broken beqause of water, lightning, .... we replace never old hardware , only if its realy old and if the site is growing.
if we replace a backbone router , then it will be re-used on a end point.
We use RB493, omnitik, RB2011, Groove, CCR, CRS, RB433, RB951, ..... the omnitik does broke more often than the 493 with lightning, in this case 1 or 2 ethernet interfaces stop working.
So if the powersupply is good , you will never have problems with mikrotik.
from our 400 meanwell power supply's there untill now not one broken , even after a lightning storm.
fake meanwell power supply's (other brand, same shape) do go broken in 2-3 years
paoloaga
Mon Aug 17, 2015 3:39 am
In my experience I never had troubles with high end routers (I have still the first RB1100 model in production). I have also lots of RB750 (around 500) installed since ~ 2009, and only a few dozens have been replaced so far (often because of external events, like surges on the ethernet interfaces).
That said, if history repeats itself, you can expect those to live at least 5 years.
normis
Mon Aug 17, 2015 9:26 am
MTBF is a syntetic calculation and is not comparable to real life observation. Of course in real life "some boards" die sooner as you wrote above. MTBF calculation does not take this into account. It simply sums the expected lifetimes of the parts used, adds some statistical variables and calculates an unrealistic number that is not helpful for real life. This is why we don't spend a lot of time calculating all the values.
Niamh94
Thu Jul 06, 2017 11:30 am
I emailed MikroTik for the MTBF of the RB450G. Their response was 120,000 hours, using this Mil-spec handbook - "Reliability Prediction of Electronic Equipment MIL-HDBK-217F"
SystemErrorMessage
Fri Jul 07, 2017 4:29 am
i still have a rb450G in use for years 24/7. The main problems i have with routerboards are simply the PSU, they break/fail too easily other than that the routerboard themselves are good. Mikrotik says they have another company that makes their PSUs, i hope they arent using them anymore as i had to replace my CCR's PSU twice, the first replacement i bought was one usually used for network related installs like cameras and other equipment usually tucked away as part of the structure, the 2nd replacement is a laptop style PSU which is working really well but i had to get a DC power jack and solder the wires onto them and glue it to the insulated part of the case.
m4t7e0
Wed Jun 19, 2019 12:26 pm
UP!
Mikrotik APs compliant with the wifi4eu minimum specs?
As request from WiFi4EU 9.2.1 What are the technical requirements for the WiFi4EU Access Points?
The technical specifications of the equipment are detailed in section 6.2.2 of the call text, as well as Article I.2 of Annex I of the Grant Agreement signed between the municipalities and the Commission.
The municipality shall ensure that each Access Point:
Supports concurrent dual-band (2,4Ghz – 5Ghz) use
Has a support cycle superior to 5 years
Has a mean time between failure (MTBF) of at least 5 years
Has a dedicated and centralised single point of management for all APs of each WiFi4EU network
Supports IEEE 802.1x
Complies with IEEE 802.11ac Wave I
Supports IEEE 802.11r
Supports IEEE 802.11k
Supports IEEE 802.11v
Is able to handle at least 50 concurrent users without performance degradation
Has at least 2x2 multiple-input-multiple-output (MIMO)
Complies with Hotspot 2.0 (Passpoint Wi-Fi Alliance certification program).
There is avaiable information for MTBF?
karlisi
Wed Jun 19, 2019 4:09 pm
UP!
These protocols are missing in Mikrotik products, so they are not compliant anyway.
Karlis
Users browsing this forum: No registered users and 19 guests
