InoX
MIKROTIK ROUTERBOARD WAP 2ND
Thu Aug 27, 2015 3:48 pm
normis
Re: MIKROTIK ROUTERBOARD WAP 2ND
Fri Aug 28, 2015 2:44 pm
MartijnVdS
Fri Aug 28, 2015 3:41 pm
I'm assuming more information will be up on routerboard.com soon as well?
normis
Fri Aug 28, 2015 3:43 pm
Yes, of course, but brochure contains all the essential info, site will contain the same
wojtekCDR
Sat Aug 29, 2015 12:54 pm
wAP 2nD on stock, white and black :)
We will make detailed photos soon.
nz_monkey
Sun Aug 30, 2015 10:50 am
Great looking product! Thanks Mikrotik.
The security screw and rear cable entry option are good ideas.
I'm also very happy to see 802.3af/at on the spec sheet :)
jarda
Sun Aug 30, 2015 10:57 am
Why the cable has to be unshielded? Aren't you able to make active poe with shielded cables?
Petzl
Sun Aug 30, 2015 3:47 pm
They did something wrong with the pcb design .... i gues there are some filters connected to ground and that 48V is to much for these components ...
honzam
Mon Aug 31, 2015 5:50 pm
How groundig with active POE? Normis please more info...
The same problem is in DynaDish5?
LAN, FTTx, Wireless. ISP operator
kwilliams
Wed Apr 20, 2016 6:37 pm
Hi guys,
I've read that you cannot use shielded cables with these units? Is that correct?
Also do they work with CAT6 cabling? i.e. Does POE & Data sent correctly?
Cheers!
Users browsing this forum: Bing [Bot] and 8 guests
