MUM Europe 2020
lctn
nstreme dual problem
Thu Aug 03, 2006 9:52 pm
I am running nstreme dual on two 532 boards with cm9s. According to the docs I should separate TX and RX by 200 Mhz. By default the config uses frequency 5180, so I left TX there, and set RX to 5320. I set both radios (boxes) to this. As soon as I change RX to 5320 the radios lose connectivity, if I set both TX and RX to 5180, everything works fine. I have tried this in a number of combinations, but the bottom line is nstreme will not connect, unless TX and RX on both radios are set to 5180.
Any ideas?
Raymond
Equis
Forum Veteran
Forum Veteran
Fri Aug 04, 2006 1:11 pm
ap1 tx same fq as ap2 rx
ap1 rx same fq as ap2 tx
Is that what you have set?
lctn
Fri Aug 04, 2006 5:16 pm
Yes, that is what I tried, but at the moment, the only way I can get them to connect is by putting all 4 cards in the two aps on 5180. If I move to any other frequency I lose connection. This is true to even if I change all 4 cards to something like 5780. The second I change them back to 5180, everything works again.
BurstNET
Fri Aug 04, 2006 5:24 pm
Is this in a lab or in the field? If in the field, it may be interefence on the higher channels...
Sure you are using 5.8GHZ antennas, and not 5.3GHZ?
SMA
lctn
Fri Aug 04, 2006 5:28 pm
If I am using 5.3, it would have been an error by wisp-router. I am not near them right now, but will verify. I am running in a lab environment, with dual feed horn, 29 db dishes, 50' apart.
Equis
Forum Veteran
Forum Veteran
Sat Aug 05, 2006 4:50 am
Not pointing at each other I hope :-)
I would start with seeing if you can make a single nstreame work on teh upper channels and go from there
Users browsing this forum: No registered users and 31 guests
