MUM Europe 2020
pturkey
Very slow connection using MikroTik, ubnt works fine.
Tue Nov 03, 2015 1:10 am
Every morning all the MikroTik CPE's have no usable connection, all the Ubiquiti M5's keep working using the same AP. They are all in the same area.
The AP is set:
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=19 band=5ghz-a/n channel-width=\
    20/40mhz-Ce country="united states2" default-authentication=no disabled=\
    no frequency=5805 hw-retries=4 mode=ap-bridge radio-name="1234" \
    rx-chains=0,1 security-profile="Somewhere" ssid=XXXXX \
    tx-chains=0,1
Using a radius server.
The CPE's Signal -66
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=25 band=5ghz-a/n channel-width=\
    no l2mtu=1600 mode=station-bridge radio-name=1234 rx-chains=0,1 \
    ssid="" tx-chains=0,1
Using a connect list.
Lakis
Forum Veteran
Forum Veteran
Re: Very slow connection using MikroTik, ubnt works fine.
Thu Nov 05, 2015 3:07 pm
Did u activate nv2 on wireless protocol TAB?
normis
Thu Nov 05, 2015 4:14 pm
Lakis - Nv2 will not work if both kinds of devices need to use the same AP (nv2 is only for MikroTik devices).
pturkey - how did you measure 'slow'? what exactly is slow?
Lakis
Forum Veteran
Forum Veteran
Fri Nov 06, 2015 3:08 pm
Sorry I meant he should try activate nv2 for a short time,all UBQ Cpe's will disconnect and make tests
Users browsing this forum: No registered users and 23 guests
