azurtem
Trainer
Trainer
Slow Wifi Internet access for Macbook Air
Tue Nov 03, 2015 8:46 pm
Hi
I have a client who roams from one site to another
He owns several Apple devices: iPhone, iPad, and MacBook Air
All their sites are equipped with RB951G-2HnD
His Wifi Internet access using the Macbook Pro is always slow
e.g. six seconds to load Google's search page
In comparison local Windows laptops have fast Wifi Internet access
This is the common Wireless setup for all sites:
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
    20/40mhz-ht-above country=france default-authentication=no disabled=no \
    distance=indoors frequency=2462 l2mtu=2290 mode=ap-bridge \
    security-profile=XXX ssid=NXXXXXX01 wireless-protocol=802.11
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
    tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=XXX \
    supplicant-identity="" unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=\
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX	\
    wpa2-pre-shared-key=\
The SSID is solely composed of capital letters, plus two digits
I recently set the Wireless-Protocol to 802.11
Before it was set to any or unspecified
But the user hasn't noticed any improvement
Any ideas ?
thanks
yann
dkalam
Re: Slow Wifi Internet access for Macbook Air
Tue Nov 03, 2015 10:33 pm
Remove tkip... Hope that helps..
azurtem
Trainer
Trainer
Wed Nov 04, 2015 8:49 am
thanks for your response
If I disable TKIP that might prevent older devices from being able to connect
uldis
Wed Nov 04, 2015 1:43 pm
Disabling tkip helped?
Most of the wireless devices supports aes encryption.
Please enable wireless-fp or wireless-cm2 package and check again.
azurtem
Trainer
Trainer
Wed Nov 04, 2015 5:58 pm
Use one of these packages instead of the standard Wireless one ?
I thought that those were linked to using FastPATH and CAPsMAN
The client's agencies are each composed of four or five users
deanMKD1
Wed Nov 04, 2015 11:49 pm
Dont make combination with wireless packages !!
Enable only one package !
Prefer wireless-cm2 if not have it then wireless-fp
Users browsing this forum: No registered users and 34 guests
