Bourbon
Rx sensibility radio
Fri Nov 06, 2015 4:29 pm
I have a problem on a site.
I have many interferences. (many networks with a signal strength between -76 and -96 dB)
Is it possible de modify the RX sensibility?
Actually the sensibility is -96db approximately, I wouldlike change it at the value -80dB.
Because, I enable DFS and the DFS change my frequency every time!
I haven't choise, I must keep the DFS.
Thank you for your help.
ericnyamu
Re: Rx sensibility radio
Mon Nov 09, 2015 4:22 pm
if you increase sensitivity you are also increasing noise so better find another quieter channel
n21roadie
Mon Nov 09, 2015 4:35 pm
What type of antenna is being used!
N21roadie,
Network 100% MT for Now?
gtj
Mon Nov 09, 2015 11:10 pm
You can try setting Noise Floor Theshold in advanced wireless settings..
Bourbon
Thu Nov 12, 2015 5:39 pm
Thank you for yours answers.
I use directive antenna. 9°/9°
I choised the best Channel.
I tested to modify the noise floor treshold. I set it at -100dB (-110dB by default.) and and my link was worst.
I enabled adaptive noise immunity,
changed HW-retry to 15,
enabled multicast helper,
tested all wireless protocol.
Others Ideas?
Thank you
Users browsing this forum: Baidu [Spider], Bing [Bot] and 29 guests
