MUM Europe 2020
azurtem
Trainer
Trainer
ACSWIM Small Omni Antennas
Mon Nov 23, 2015 4:25 pm
Hi
Everyone seems to agree that 2.4GHz antennas are physically different from 5 GHz antennas
Yet the description for the Mikrotik ACSWIM antenna indicates : 2.4-5.8GHz Swivel Antenna
This little swivel antenna can cater for both frequency bands.
Is the dual band possible because of the size of the antenna i.e. are all such small omni antennas capable of operating in both frequency bands ?
pukkita
Trainer
Trainer
Re: ACSWIM Small Omni Antennas
Mon Nov 23, 2015 6:05 pm
Yes, though effective gain will probably differ depending on the band used. Neither mikrotik nor anyone can produce antennas equally optimized for both bands, is a matter of physics.
Don't be afraid to choose a device with no external antennas if suitable; for the gains used for WLANs, 10 times out of 10 a device with internal antennas (RB951 in 2.4GHz band is a great example) will outperform those with rubberduck-type external ones, as the connector and pigtail losses usually null the external one.
You also rule out one of the most common failing components: connectors and pigtails.
What's you intended application?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
azurtem
Trainer
Trainer
Mon Nov 23, 2015 6:31 pm
Thanks Pukkita
The use is for indoor APs
The need was to understand the degree of importance linked to choosing the right accompanying external omni antenna
chechito
Mon Nov 23, 2015 8:04 pm
in fact for indoors high gain omni antenna cause the ap to get more noise and interference from environment and too wide coverage area with low overall performance
i think for indoor internal low gain antenna are best
azurtem
Trainer
Trainer
Mon Nov 23, 2015 8:34 pm
Chechito
Thanks for your answer
What would you say constitues high gain ?
I'm was refering to (max) 6dbi omni rubber duck antennas
chechito
Tue Nov 24, 2015 1:31 am
Chechito
keep in mind that internal antennas normally are 3dbi if you use 6 dbi you are duplicating the energy irradiated horizontally lowering the energy irradiated vertically, like a donut pattern, maybe 6dbi its a good limit, it depends of your implementation.
my opinion its about avoiding the "bigger its better" assumption
because that assumption some people put 10 or 13 dbi omni antennas on indoor implementations :lol:
in this link the topic its better exlained than i can do
http://www.cisco.com/c/en/us/products/c ... a1a3e.html
azurtem
Trainer
Trainer
Tue Nov 24, 2015 7:21 am
Excellent,
I will shortly brush up my knowledge on this important subject
Cheers mate
yann
Users browsing this forum: No registered users and 31 guests
