MUM Europe 2020
anuser
Maximum concurrent/active SSIDs/Virtual APs?
Mon Dec 14, 2015 4:30 pm
I searched but haven´t found any information. So how many SSIDs or virtual access points can I configure and run actively on a RouterOS wifi access point? e.g. my current devices support 8 SSIDs per radio concurrently and I wish I could have more
Regards
InoX
Re: Maximum concurrent/active SSIDs/Virtual APs?
Mon Dec 14, 2015 4:59 pm
I don't think there is a limit but the more VAP's, the more performance will drop.
The downside of enabling more SSIDs is that it creates more channel utilization due to overhead.
chechito
Mon Dec 14, 2015 5:12 pm
here
http://www.revolutionwifi.net/revolutio ... lator.html
you can calculate overhead of using multiple ssids
anuser
Mon Dec 14, 2015 10:09 pm
No limit? Great.
33% loss with 10 SSIDs, well it will work either
Thanks!
chechito
Tue Dec 15, 2015 2:11 am
No limit? Great.
Thanks!
dont underestimate it
33% is a lot of performance you loose, because is 33% of total air time, because that are colored red in the graphic
the impact of it can be mitigated changing the bitrate of beacons are using, for example 10 ssids transmitted at default datarate of 1mbps uses 33% of airtime, but 10 ssids transmitted at 6mbps datarate only takes 5-6% of airtime
Users browsing this forum: aysan and 28 guests
