rzirzi
MT6.xx Nstreme+Polling disconnections
Thu Dec 17, 2015 9:51 am
There is still a problem with RouterOS 6.xx and Nstreme+Polling radio disconnections. Comparing to ROS 5.2x it's not working good. At the ROS 6.xx there is much more disconnections CPE from AP - both at the same 6.33.3 version (checked at every previos 6.xx version - the same).
MikroTik team - cold You repair thet annoying problem with ROS 6.xx version. At this point we don't upgrade to 6.xx due to radio problems with it.
HaQs
Re: MT6.xx Nstreme+Polling disconnections
Thu Dec 17, 2015 4:55 pm
I confirm this bug
rzirzi
Mon Dec 21, 2015 12:49 pm
We are downgrading to MikroTik ROS 5.26 for best radio connections with Nstreme+Polling 5GHz one-polarization connections.
Anyone else have that problems? We have checked it at many MT Access Points - the same problem. The only solution is downgrade to ROS 5.2x.
soulflyhigh
Mon Dec 21, 2015 3:11 pm
I think it became serious issue in one of the versions after v6.23
We have almost no problems (with nstreme and disconnections) when using old v6.5 or older v5.xx.
MTCRE, MTCTCE, MTCSE
rzirzi
Wed Dec 23, 2015 5:22 pm
The only solution is downgrade to ROS 5.xx. After that - no more problems with CPE disconnections from MT AP (Nstreme+Polling one polarisation). MikroTik team don't ansering for that problem (of course I have send e-mail to support...).
rzirzi
Tue Apr 19, 2016 9:09 am
Upgraded to MT 6.35 - STILL THE SAME PROBLEM! with radio disconnections at 5GHz A and Nstreme+Polling.
MikroTik - when could we expect any improvement?
rzirzi
Sun Sep 25, 2016 10:24 am
There is even worse with newest MT6.37 - with radio disconnections!
After many tests: IT APPEARS AT HIGH RB CPU USAGE.
MikroTik Team could You repair that problem with MT 6.xx radio disconnections?
Users browsing this forum: audimers and 34 guests
