sekil
slow nv2, big ping, unstable speed, low tx speed
Tue Jan 12, 2016 8:58 am
Hi..
i,m use RB921UAGS-5SHPacD-NM with ubiquity AM-V5G-Ti
and have very very unstable result -
clients max 5km
base have 25 power tx
client have max 15 power tx
with nv2 bandwidth max 5mbit
with 802.11 - 30-40 mbit
big and unstable ping - 40-100ms
most client have low tx rate - 6mb
where problem???
p3rad0x
Long time Member
Long time Member
Re: slow nv2, big ping, unstable speed, low tx speed
Tue Jan 12, 2016 12:46 pm
How does the ping look when you set the AP to nstream?
You could try and change the frequency
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
sekil
Tue Jan 12, 2016 10:22 pm
deleted...
sekil
Wed Jan 13, 2016 8:53 am
P.S. clients sxt 5lite.
Frequency change not help!
i'm try 5280, 5180, 5160..
tests:
nv2
nstream
802.11
PaulsMT
Wed Jan 13, 2016 11:01 am
Are you using default wireless settings on both sides ? Check if there is set max channel-width, also look if on both ends is enabled fastest bands, try to repeat tests with whole range of supported frequencies.
Check if both chains are enabled (tx-chains=0,1 rx-chains=0,1):
/interface wireless print advanced
Also make sure you are using latest rOS with enabled wireless-cm2 package.
p3rad0x
Long time Member
Long time Member
Wed Jan 13, 2016 11:44 am
Hi I have a question.
What difference is there between Wireless-fp and cm2?
Does it provide more stable connectivity with higher speeds?
PaulsMT
Wed Jan 13, 2016 12:05 pm
Wireless-cm2 is the latest wireless package, it contains more optimizations compared to the wireless-fp. We suggest to use cm2 package if it's possible.
sekil
Wed Jan 13, 2016 12:42 pm
thank..
i'm try cm2 and try test again.
p.s. we buy only 3 freq - 5180, 5280, 5160 - other - i cant use...
p..s. May be sxt 5 lite need change to other sxt (for clients with distance > 3 km)? and if yes what can i use ?
sekil
Wed Jan 13, 2016 2:34 pm
i'm try cm2 and yes - speed up - but nv2 slowly then 802.11 about 2.5x
Ping less..
But all clients have tx ccq < rx ccq - why ?
nv2
802.11
honzam
Wed Jan 13, 2016 7:30 pm
Hello.
How much clients do you have on this sector? In first picture I see 23 clients. It is all?
In my opinion have mikrotik some problems with nv2 when on sector is more then 20-25 clients.
When is connected fewer clients so speedtest is good? You can simulate it by acces list.
Mark
LAN, FTTx, Wireless. ISP operator
sekil
Wed Jan 13, 2016 8:01 pm
Hello.
Mark
Base have 24 clients.
Other base have 16 clients.
Yes other base dont have this problem (while... ), and when i'm starting connecting clients - i'm don't have any problems on two bases - speed 30-40-50 mbit - ping 1-2ms.
But with more clients - i have very unstable result.
I'm try change tdma period from max to min - this not help - only make other problems - big ping or small speed.
What about SXT lite - maybe this not good for distance 3-5 km ?
honzam
Wed Jan 13, 2016 8:54 pm
I think - problem is in number of clients. We have the same problem on sectors.
When is about 25 clients on AP. It is high time to add additional AP...
sekil
Wed Jan 13, 2016 10:22 pm
what base (and sector antenna) and stations are you use? what speed you need for clients ? what freq you use ? what distance ?
honzam
Wed Jan 13, 2016 10:40 pm
rb912-5HnD, sector antenna - Raytra UIP514.61, stations (rb411,rb711,sxt, sextant), speed 10-20Mbit, distance 0,1-3km, freq 5500-5700Mhz
sekil
Wed Jan 13, 2016 11:09 pm
you use sector not mimo with mimo base ? may be you need disable one channel ?
and you have unstable result for all bases?
bandwidth tests have stable speed? i'm have very very unstable speedtest - speed go from min to max every second...
you can try change tx power on base and stations?
this very bad... (// rocket m5 have 34 clients - no problem)
p3rad0x
Long time Member
Long time Member
Thu Jan 14, 2016 12:32 pm
Jip the amount of clients kills the nv2 performance.
I have a basebox 5 with about 45 clients connected.
5Mbit download and about 1 Mbit upload, all clients are within 10km.
Adding a new ap sometimes isn't possible because there is no tower space left.
I think nv2 can be improved if MT adds a secondary cpu to offload the TDMA, if I understand correctly current NV performance is being limited by the atheros chip.
sekil
Thu Jan 14, 2016 1:51 pm
why upload very slow? what stations ?
And if nv2 perfomance very bad - why i'm need use nv2 instead of 802.11 ?
This is very strange and stupid situations!
45 clients - this wil be good for me :) (but i'm need 5mbit download and upload)
gius64
Thu Jan 14, 2016 5:27 pm
What if I use wireless-cm2 on AP and wireless-fp on clients? Can this create issue like slow speed and so on?
ronniee
Thu Jan 14, 2016 11:49 pm
I also want to ask, these packages can work together?
for ex. if I enable wireless-cm2 package on AP, the client side with wireless-fp package will connect to AP?
and if I enable wireless-cm2 package, the other package will be disabled automatically?
in the latest 6.33.5 the fp is enabled, and cm2 is disabled
gius64
Fri Jan 15, 2016 12:01 am
I can say that for sure clients will connect to AP, but I can't speak about performances (I tested only connection on a link).
Enabling wireless-cm2, the other package will be disabled automatically.
I would like to hear from MikroTik about performances between wireless-fp clients and wireless-cm2 AP.
p3rad0x
Long time Member
Long time Member
Fri Jan 15, 2016 1:58 pm
The stations is RB groove 5hn and RB SXT Lite 5's if the signal is below -60dBm
The issue with 802.11 in my opinion is it is not reliable enough the bring stable latency and bandwidth.
Can you share a screenshot of your spectral history for us?
sekil
Thu Jan 21, 2016 12:15 pm
my base dont support spectral scan!
i'm get spectral from rocket m5 (5100-5500)
my freq - 5180, 5280, 5260, 5300
sekil
Wed Feb 10, 2016 8:49 am
maybe problem solved..
i'm change station wds to station bridge for all clients - and speeds, pings go to normal.. need test..
wds mode create many many system wifi traffic (250-300kbit for each client) - this is kill all wifi
official mikroitk forum?? mikrotik support?? No - not heard..
pukkita
Trainer
Trainer
Thu Feb 11, 2016 4:44 pm
I understand your frustration, but I should disagree, that's not fair.
You didn't post a single export of any wireless configuration on any post, let alone which ROS version you were using.
Why were you using wds to start with? AFAIK nobody here has crystal balls...
Additionaly, this is an user forum, not the Mikrotik support channel (you should use email for that), even though, MT staff has replied twice to this thread.
Kudos however for posting what was the problem, that makes the forum much more useful as a self-support resource, specially if you confirm the tests were successful.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
n21roadie
Thu Feb 11, 2016 6:48 pm
+1
N21roadie,
Network 100% MT for Now?
Users browsing this forum: No registered users and 28 guests
