ChildOTK
Equipment Recommendation
Tue Feb 02, 2016 5:59 pm
Good Day All,
I currently have an EnGenius ECB600 wireless AP which supports up to 16 SSIDs, 8 for each respective band. As well as VLAN tagging for each respective SSID. I know with RouterOS based products the VLAN tagging is not an issue.
I am looking to replace my ECB600 with something better and newer. I have a RB450G at the core of my internet service, and the ECB600 doing my wireless features.
Can anybody recommend a good wireless AP that is RouterOS / Mikrotik based?
Thank you!
fibernetwork
Re: Equipment Recommendation
Thu Mar 10, 2016 6:20 am
You may take TP-link as a reference.
Fiberstore -James
jarda
Thu Mar 10, 2016 6:35 am
mennowz
Trainer
Trainer
Fri Mar 11, 2016 4:37 pm
+1 for Jarda!
Just to make sure : You don't ACTUALLY use 8 SSID's right?, if you do, you should really take a look at 802.1x (DOT1x).
The more SSID's you use, the more overhead you are creating and the more airtime you use at BASIC rates, which is never a good thing.
Nice one, replacing those Enginiuses :D
Best regards,
Menno
Certified Mikrotik trainer in the BeNeLux!. http://www.mikrotiktraining.nl
Users browsing this forum: No registered users and 71 guests
