csi
CAPsMAN performance issues
Wed Mar 02, 2016 2:36 pm
my first post and hopefully I do it well. First, many thanks to MikroTik for the hard- and software. I really enjoy it!
Regarding my topic. I use a RB3011 with two access points, hAP ac and hAP ac lite. The use of CAPsMAN is attractive, but I identified some issues and would ask the community to their experience.
Before the questions raises up, I use the latest stable RouterOS Release 6.34.2 and the wireless-cm2 package. All bandwidth tests are done with iperf3 with standard setting and a running time of 60 seconds. For the final result I have choose the best of five runs. As Radio I uses the 5 GHz range, because I have no other usage in this band in this environment. My system was a MacBook Pro early 2013 with N-standard and three chains.
For the results: “CAPsMAN connected via layer-2” means the discovered CAPsMAN service over layer 2 and no IP configuration. “CAPsMAN connected via layer-3” means configured IP addresses on both parts. The CPU usage on all components was always ok and not a limiting factor. Also the system was close to the access point for an excellent connection and high “Tx Rate”.
Here are my performance results in different setups:
  • hAP ac lite - configured with forwarding to CAPsMAN connected via layer-3
  • Tx Rate 135 Mbit
  • 26 Mbit/s throughput
  • hAP ac lite - configured with forwarding to CAPsMAN connected via layer-2
  • Tx Rate 135 Mbit
  • 65 Mbit/s throughput
  • hAP ac lite - configured without CAPsMAN connected via layer-2 bridge
  • Tx Rate 150 Mbit
  • 84 Mbit/s throughput
  • hAP ac - configured with forwarding to CAPsMAN connected via layer-3
  • Tx Rate 450 Mbit
  • 34,5 Mbit/s throughput
  • hAP ac - configured with forwarding to CAPsMAN connected via layer-2
  • Tx Rate 450 Mbit
  • 76 Mbit/s throughput
  • hAP ac - configured with local forwarding connected via layer-2 bridge
  • Tx Rate 450 Mbit
  • 73,9 Mbit/s throughput
  • hAP ac - configured without CAPsMAN connected via layer-2 bridge
  • Tx Rate 450 Mbit
  • 149 Mbit/s throughput
The values tell it own tale.
If you have a closer look to the iperf3 output, then it’s clear why CAPsMAN configuration has a lower throughput.
CAPsMAN enabled and some drop downs. Looks not like stable connection.
iperf3 -c 192.168.11.11 -t 60
Connecting to host 192.168.11.11, port 5201
[  4] local 192.168.11.10 port 60126 connected to 192.168.11.11 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  19.7 MBytes   165 Mbits/sec
[  4]   1.00-2.00   sec  22.9 MBytes   192 Mbits/sec
[  4]   2.00-3.00   sec  26.4 MBytes   222 Mbits/sec
[  4]   3.00-4.00   sec  23.7 MBytes   199 Mbits/sec
[  4]   4.00-5.00   sec  26.3 MBytes   221 Mbits/sec
[  4]   5.00-6.01   sec  11.3 MBytes  94.2 Mbits/sec
[  4]   6.01-7.00   sec   460 KBytes  3.78 Mbits/sec
[  4]   7.00-8.00   sec  1.46 MBytes  12.2 Mbits/sec
[  4]   8.00-9.00   sec  1.20 MBytes  9.99 Mbits/sec
[  4]   9.00-10.00  sec  1.07 MBytes  9.01 Mbits/sec
[  4]  10.00-11.00  sec  1.09 MBytes  9.20 Mbits/sec
[  4]  11.00-12.01  sec   660 KBytes  5.38 Mbits/sec
[  4]  12.01-13.00  sec  1.19 MBytes  10.1 Mbits/sec
[  4]  13.00-14.00  sec  1.63 MBytes  13.6 Mbits/sec
[  4]  14.00-15.00  sec   619 KBytes  5.08 Mbits/sec
[  4]  15.00-16.00  sec   806 KBytes  6.62 Mbits/sec
[  4]  16.00-17.01  sec  1.18 MBytes  9.83 Mbits/sec
[  4]  17.01-18.00  sec   810 KBytes  6.67 Mbits/sec
[  4]  18.00-19.00  sec  7.82 MBytes  65.6 Mbits/sec
[  4]  19.00-20.00  sec  7.63 MBytes  64.0 Mbits/sec
[  4]  20.00-21.00  sec  5.12 MBytes  42.9 Mbits/sec
[  4]  21.00-22.00  sec  20.2 MBytes   170 Mbits/sec
[  4]  22.00-23.00  sec  14.9 MBytes   125 Mbits/sec
[  4]  23.00-24.00  sec  18.8 MBytes   157 Mbits/sec
[  4]  24.00-25.00  sec  24.6 MBytes   206 Mbits/sec
[  4]  25.00-26.00  sec  18.4 MBytes   154 Mbits/sec
[  4]  26.00-27.00  sec  22.3 MBytes   187 Mbits/sec
[  4]  27.00-28.00  sec  23.4 MBytes   196 Mbits/sec
[  4]  28.00-29.00  sec  20.4 MBytes   171 Mbits/sec
[  4]  29.00-30.00  sec  17.4 MBytes   146 Mbits/sec
[  4]  30.00-31.00  sec  5.60 MBytes  46.9 Mbits/sec
[  4]  31.00-32.01  sec  1.53 MBytes  12.8 Mbits/sec
[  4]  32.01-33.00  sec  1.49 MBytes  12.5 Mbits/sec
[  4]  33.00-34.00  sec  6.54 MBytes  54.9 Mbits/sec
[  4]  34.00-35.01  sec  17.4 MBytes   146 Mbits/sec
[  4]  35.01-36.00  sec  9.13 MBytes  77.0 Mbits/sec
[  4]  36.00-37.00  sec  14.5 MBytes   121 Mbits/sec
[  4]  37.00-38.00  sec  17.4 MBytes   146 Mbits/sec
[  4]  38.00-39.00  sec  19.6 MBytes   164 Mbits/sec
[  4]  39.00-40.00  sec   808 KBytes  6.62 Mbits/sec
[  4]  40.00-41.00  sec   547 KBytes  4.49 Mbits/sec
[  4]  41.00-42.00  sec  3.65 MBytes  30.7 Mbits/sec
[  4]  42.00-43.00  sec  1.65 MBytes  13.8 Mbits/sec
[  4]  43.00-44.00  sec   908 KBytes  7.44 Mbits/sec
[  4]  44.00-45.00  sec  1.06 MBytes  8.93 Mbits/sec
[  4]  45.00-46.00  sec   304 KBytes  2.49 Mbits/sec
[  4]  46.00-47.00  sec  16.5 MBytes   139 Mbits/sec
[  4]  47.00-48.00  sec  16.4 MBytes   138 Mbits/sec
[  4]  48.00-49.00  sec  16.0 MBytes   134 Mbits/sec
[  4]  49.00-50.00  sec  16.3 MBytes   137 Mbits/sec
[  4]  50.00-51.00  sec  10.4 MBytes  86.9 Mbits/sec
[  4]  51.00-52.00  sec  2.27 MBytes  18.9 Mbits/sec
[  4]  52.00-53.01  sec   711 KBytes  5.82 Mbits/sec
[  4]  53.01-54.00  sec  1016 KBytes  8.37 Mbits/sec
[  4]  54.00-55.00  sec  1.21 MBytes  10.1 Mbits/sec
[  4]  55.00-56.00  sec  9.74 MBytes  82.0 Mbits/sec
[  4]  56.00-57.00  sec  5.27 MBytes  44.0 Mbits/sec
[  4]  57.00-58.00  sec   854 KBytes  7.00 Mbits/sec
[  4]  58.00-59.00  sec   667 KBytes  5.46 Mbits/sec
[  4]  59.00-60.00  sec   498 KBytes  4.09 Mbits/sec
[  4]   0.00-60.00  sec   543 MBytes  75.9 Mbits/sec                  sender
[  4]   0.00-60.00  sec   543 MBytes  75.9 Mbits/sec                  receiver
iperf Done.
Without CAPsMAN and local bridging, it looks ok and stable.
[  4] local 192.168.11.10 port 59373 connected to 192.168.11.11 port 5201
[  4]   0.00-1.00   sec  18.6 MBytes   156 Mbits/sec
[  4]   1.00-2.00   sec  16.3 MBytes   137 Mbits/sec
[  4]   2.00-3.00   sec  17.1 MBytes   143 Mbits/sec
[  4]   3.00-4.00   sec  15.6 MBytes   131 Mbits/sec
[  4]   4.00-5.00   sec  18.2 MBytes   153 Mbits/sec
[  4]   5.00-6.00   sec  14.5 MBytes   122 Mbits/sec
[  4]   6.00-7.00   sec  14.4 MBytes   121 Mbits/sec
[  4]   7.00-8.00   sec  16.7 MBytes   140 Mbits/sec
[  4]   8.00-9.00   sec  19.6 MBytes   165 Mbits/sec
[  4]   9.00-10.00  sec  15.0 MBytes   126 Mbits/sec
[  4]  10.00-11.00  sec  16.3 MBytes   136 Mbits/sec
[  4]  11.00-12.00  sec  16.5 MBytes   139 Mbits/sec
[  4]  12.00-13.00  sec  17.1 MBytes   144 Mbits/sec
[  4]  13.00-14.00  sec  15.9 MBytes   133 Mbits/sec
[  4]  14.00-15.00  sec  18.6 MBytes   156 Mbits/sec
[  4]  15.00-16.00  sec  17.1 MBytes   144 Mbits/sec
[  4]  16.00-17.00  sec  16.8 MBytes   141 Mbits/sec
[  4]  17.00-18.00  sec  16.7 MBytes   140 Mbits/sec
[  4]  18.00-19.00  sec  17.3 MBytes   145 Mbits/sec
[  4]  19.00-20.00  sec  15.6 MBytes   131 Mbits/sec
[  4]  20.00-21.00  sec  18.9 MBytes   158 Mbits/sec
[  4]  21.00-22.00  sec  17.4 MBytes   146 Mbits/sec
[  4]  22.00-23.00  sec  17.8 MBytes   149 Mbits/sec
[  4]  23.00-24.00  sec  17.6 MBytes   147 Mbits/sec
[  4]  24.00-25.00  sec  19.1 MBytes   160 Mbits/sec
[  4]  25.00-26.00  sec  20.4 MBytes   171 Mbits/sec
[  4]  26.00-27.00  sec  19.0 MBytes   159 Mbits/sec
[  4]  27.00-28.00  sec  18.9 MBytes   159 Mbits/sec
[  4]  28.00-29.00  sec  18.8 MBytes   158 Mbits/sec
[  4]  29.00-30.00  sec  19.2 MBytes   161 Mbits/sec
[  4]  30.00-31.00  sec  18.6 MBytes   156 Mbits/sec
[  4]  31.00-32.00  sec  18.0 MBytes   151 Mbits/sec
[  4]  32.00-33.00  sec  17.5 MBytes   147 Mbits/sec
[  4]  33.00-34.00  sec  17.4 MBytes   146 Mbits/sec
[  4]  34.00-35.00  sec  14.3 MBytes   120 Mbits/sec
[  4]  35.00-36.00  sec  18.8 MBytes   158 Mbits/sec
[  4]  36.00-37.00  sec  18.6 MBytes   156 Mbits/sec
[  4]  37.00-38.00  sec  18.5 MBytes   156 Mbits/sec
[  4]  38.00-39.00  sec  17.7 MBytes   148 Mbits/sec
[  4]  39.00-40.00  sec  18.4 MBytes   155 Mbits/sec
[  4]  40.00-41.00  sec  17.3 MBytes   145 Mbits/sec
[  4]  41.00-42.00  sec  19.3 MBytes   162 Mbits/sec
[  4]  42.00-43.00  sec  19.8 MBytes   166 Mbits/sec
[  4]  43.00-44.00  sec  18.5 MBytes   155 Mbits/sec
[  4]  44.00-45.00  sec  16.9 MBytes   142 Mbits/sec
[  4]  45.00-46.00  sec  14.6 MBytes   122 Mbits/sec
[  4]  46.00-47.00  sec  19.0 MBytes   160 Mbits/sec
[  4]  47.00-48.00  sec  15.0 MBytes   126 Mbits/sec
[  4]  48.00-49.00  sec  17.8 MBytes   150 Mbits/sec
[  4]  49.00-50.00  sec  20.8 MBytes   175 Mbits/sec
[  4]  50.00-51.00  sec  16.9 MBytes   142 Mbits/sec
[  4]  51.00-52.00  sec  20.2 MBytes   170 Mbits/sec
[  4]  52.00-53.00  sec  19.5 MBytes   164 Mbits/sec
[  4]  53.00-54.00  sec  20.1 MBytes   168 Mbits/sec
[  4]  54.00-55.00  sec  20.5 MBytes   172 Mbits/sec
[  4]  55.00-56.00  sec  18.0 MBytes   151 Mbits/sec
[  4]  56.00-57.00  sec  18.3 MBytes   154 Mbits/sec
[  4]  57.00-58.00  sec  18.4 MBytes   154 Mbits/sec
[  4]  58.00-59.00  sec  16.6 MBytes   139 Mbits/sec
[  4]  59.00-60.00  sec  17.7 MBytes   148 Mbits/sec
[  4]   0.00-60.00  sec  1.04 GBytes   149 Mbits/sec                  sender
[  4]   0.00-60.00  sec  1.04 GBytes   149 Mbits/sec                  receiver
iperf Done.
Can anyone confirm this behavior or has similar experience? Or is there a hidden switch I have missed to configure?
Many thanks in advanced
Christian
commander86
Re: CAPsMAN performance issues
Thu Mar 10, 2016 10:15 pm
i have the same Problem with 3011 as Capsman and hap AC but no Solution. Hope it's an Firmware Bug in 6.34.2 :(
Greetings from Cologne
Sven
EDIT: I've checked again ... now i've got about 80 Mbit/s via the ac Link with iPhone as Client. I have really NO idea why this happened.
csi
Fri Mar 11, 2016 12:15 am
Hi Sven,
in the mean time I have tested something. One of the options I checked was L2MTU size. On the hAP ac lite I set it to 2028 Byte (that was the max possible value on the hAP ac lite box). On the hAP ac I set it to 2304 Byte. You have to set it on both sites of course.
With this values I was able to increase the performance. Here are some figures based on the hAP ac in the 5 GHz band.
  • CAPsMAN configured with forwarding to CAPsMAN connected via layer-3
    Tx Rate 405 MBit
    124 Mbit/s throughput
    CAPsMAN configured with forwarding to CAPsMAN connected via layer-2
    Tx Rate 405 MBit
    173 Mbit/s throughput
    CAPsMAN configured with local forwarding connected via layer-2 bridge
    Tx Rate 405 MBit
    215 Mbit/s throughput
The lower throughput in layer-3 mode is based on additional processing within the firewall.
Would be nice if you can try it on your boxes too and provide your values here.
Many thanks
Christian
Users browsing this forum: rgroothuis and 24 guests
