azurtem
Trainer
Trainer
wAP doesn't work with CAPsMAN
Sat Apr 23, 2016 10:51 pm
Hi
After much fiddling about, and lost time, with wAP devices and ROS upgrades
I finally manage to update to 6.35 without any issues
Now the problem is with CAPsMAN v2
The wAP is accessible, and I can connect to the network
but then a few seconds later I get disconnected,
then a few seconds later I get reconnected again,
and this goes on incessantly: on, off, on, off, ...
If configured as an individual AP the wAP devices behave properly
Anyone get these to operate correctly with CAPSsMAN ?
thanks
yann
annefmoreno
Re: wAP doesn't work with CAPsMAN
Mon Apr 25, 2016 9:12 am
Install a new temporary CAPsMAN v2 router in same network where the current CAPsMAN router is and start enabling/upgrading wireless-cm2 package on the CAPs. All CAPs with the v2 will connect to the new temporary CAPsMAN v2 router. After every CAP is upgraded to v2, upgrade your current CAPsMAN to v2 and then turn off the temporary CAPsMAN v2 router.
azurtem
Trainer
Trainer
Mon Apr 25, 2016 11:10 am
Thanks annefmoreno
I think the problem is more an issue with automatic channel selection rather than anything else
I will use CAPsMAN but configure the channel selections for each AP
CAPsMAN will still retain it's raison d'être as a centralised AP management console.
tikomikr
Mon Oct 17, 2016 3:42 pm
Hi
We had same issue when forgot to change wAP MACs and all my wAPs left with identical MAC on LAN interfaces.
Users browsing this forum: No registered users and 56 guests
