metricmoose
CAPsMAN - Local Forwarding with Management IP
Mon Apr 25, 2016 5:59 am
I am having difficulty getting this configuration to work. I currently have CAPsMAN setup and working to use a bridge as a datapath, though I would like to move to using Local Forwarding.
I have two SSIDs that I have VLANs for, a home network on VLAN 100 and a secondary network on VLAN 101. My APs (hAP AC and hAP AC Lite) will have ether1 configured as a trunk in the switch chip and a couple access ports each for VLAN 100 and 101. The APs and other network devices have IPs in the VLAN 100 network. All VLAN connectivity works through the configured switchports.
I enabled CAPsMAN on the AP, went into the CAPsMAN router to enable local forwarding, changed the VLAN mode to "use tag" and specified the VLAN ID. The AP picked up the config, though my wifi devices were not able to get any sort of network access after connecting to the SSIDs.
I was poking around at other posts on the forum and one poster had their VLAN interfaces on the bridge rather than the trunk port, but it didn't seem to make a difference either way. Neither did putting the wireless interfaces in the bridge. Is there something I'm missing?
# jan/02/1970 01:10:01 by RouterOS 6.34.3
# software id = FXGL-NC1N
add name=bridge-local
set [ find default-name=ether2 ] master-port=ether1
set [ find default-name=ether3 ] master-port=ether1
set [ find default-name=ether4 ] master-port=ether1
set [ find default-name=ether5 ] master-port=ether1
/interface wireless
# managed by CAPsMAN
# channel: 2412/20/gn(30dBm), SSID: XXXXXXXX, local forwarding
set [ find default-name=wlan1 ] disabled=no rx-chains=0 ssid=XXXXXXXX \
    tx-chains=0
# channel: 5765/20-eC/ac(30dBm), SSID: XXXXXXXX, local forwarding
set [ find default-name=wlan2 ] disabled=no ssid=XXXXXXXX
/interface vlan
add interface=bridge-local name=vlan100 vlan-id=100
add interface=bridge-local name=vlan101 vlan-id=101
add interface=bridge-local name=vlan102 vlan-id=102
set 0 vlan-header=add-if-missing vlan-mode=secure
set 1 default-vlan-id=100 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=100 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=100 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=100 vlan-header=always-strip vlan-mode=secure
set 5 vlan-header=add-if-missing vlan-mode=secure
/ip hotspot profile
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
/system logging action
set 1 disk-file-name=log
add bridge=bridge-local interface=ether1
add ports=switch1-cpu,ether1,ether2,ether3,ether4,ether5 switch=switch1 \
    vlan-id=100
    vlan-id=101
    vlan-id=102
/interface wireless cap
set discovery-interfaces=vlan100 enabled=yes interfaces=wlan2,wlan1
add address=192.168.1.12/24 interface=vlan100 network=192.168.1.0
/system identity
set name="Downstairs AP"
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
annefmoreno
Re: CAPsMAN - Local Forwarding with Management IP
Mon Apr 25, 2016 9:11 am
CAPsMAN v2 is NOT compatible with current CAPsMAN v1 (CAPsMAN v1 CAP devices will not be able to connect to CAPsMAN v2 and CAPsMAN v2 CAP devices will not be able to connect to CAPsMAN v1). It means that both CAPsMAN and CAP devices should have wireless-cm2 package enabled/installed in order to make CAPsMAN v2 system to work.
metricmoose
Tue Apr 26, 2016 1:47 am
I guess I didn't mention, though all devices are running CAPsMAN v2. In the posted configuration, it will provision just fine, though I cannot pass any data through it.
Users browsing this forum: No registered users and 56 guests
