viktik
How to disable WPS button in RB951Ui-2nD with rOS 6.32.4?
Fri May 13, 2016 1:42 pm
I have several RB951Ui-2nD but RouterOS 6.32.4 doesn't have option WPS for disable it.
Anyone know how to disable the WPS button?
Thanks a lot,
Aufan388
Re: How to disable WPS button in RB951Ui-2nD with rOS 6.32.4?
Fri May 13, 2016 2:23 pm
Tyep in your terminal or just copy and paste :)
/interface wireless set wps-mode=disabled
Aufan388
Fri May 13, 2016 2:25 pm
in the future, you can find the wireless setting on the terminal by typing:
/interface wireless export
viktik
Sat May 14, 2016 12:45 am
This command not exists in this version:
[admin@XX] > /interface wireless set wps-mode=disabled
expected end of command (line 1 column 33)
WPS not exists:
[admin@XX] > /interface wireless export
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=spain disabled=no \
    frequency=auto mode=ap-bridge ssid=XX wireless-protocol=802.11
pe1chl
Sat May 14, 2016 1:29 pm
Then why don't you upgrade the RouterOS?
scampbell
Trainer
Trainer
Sun May 15, 2016 6:16 am
Also try /system package print
You may be using wireless-fp which does not support WPS anyway :-)
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
viktik
Tue May 17, 2016 12:42 am
[admin@XXX] > /system package print
Flags: X - disabled
 #   NAME                                     VERSION                                     SCHEDULED
 0   routeros-mipsbe                          6.32.4
 1   system                                   6.32.4
 2 X wireless-cm2                             6.32.4
 3 X ipv6                                     6.32.4
 4   wireless-fp                              6.32.4
 5   hotspot                                  6.32.4
 6   dhcp                                     6.32.4
 7   mpls                                     6.32.4
 8   routing                                  6.32.4
 9   ppp                                      6.32.4
10   security                                 6.32.4
11   advanced-tools                           6.32.4
In hAp lite version I had wps for enable/disable. hAp lite use smips routeros but it had wps in 6.32.4 version.
scampbell
Trainer
Trainer
Fri Sep 02, 2016 6:49 am
enable wireless-cm2 and reboot - WPS should be back. :-)
___________________
beta580gtx
Fri Sep 02, 2016 7:07 am
hi, Double click your wireless interface, click advanced mode and you will see WPS option, now you can click and disable it!
Have a good day!
normis
Fri Sep 02, 2016 12:53 pm
You want to disable WPS, but your version does not have WPS. So it is already disabled.
Users browsing this forum: No registered users and 72 guests
