total13
Wireless clients keep getting disconnected/reconnected
Thu Jul 21, 2016 11:11 am
Hello!
I have problem with RB2011UiAS-2HnD v6.34.5 (was downgraded from v6.64.6 that has similar problem).
Is it plain hardware fault (wireless module)?
Wireless clients keep getting disconnected, few seconds after getting connection. I have tested with completely open wireless (no auth) and there is same problem, so it is not wrong auth. I have enclosed excerpt from log:
07:10:33 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:33 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:33 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:34 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:34 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: reassociating
07:10:34 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, ok
07:10:34 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:34 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:34 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, received disassoc:
authentication not valid (2)
07:10:34 wireless,info wlan_guest: data from unknown device 9C:4E:36:D3:84:FC, sent de
auth
ept
07:10:36 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:36 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: reassociating
07:10:36 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, ok
07:10:36 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:36 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:36 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, received disassoc:
07:10:36 wireless,info wlan_guest: data from unknown device 9C:4E:36:D3:84:FC, sent de
auth
ept
07:10:37 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:37 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: reassociating
07:10:37 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, ok
07:10:37 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:37 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:37 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, received disassoc:
07:10:38 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:38 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:38 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:39 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:39 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: reassociating
07:10:39 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, ok
07:10:39 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:39 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
ept
07:10:39 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, received deauth: se
nding station leaving (3)
07:10:39 wireless,info wlan_guest: data from unknown device 9C:4E:36:D3:84:FC, sent de
auth
auth
07:10:40 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:40 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:40 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:40 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, received disassoc:
07:10:42 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:42 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:42 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:43 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC attempts to associate
07:10:43 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: reassociating
07:10:43 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, ok
07:10:43 wireless,debug wlan_guest: 9C:4E:36:D3:84:FC not in local ACL, by default acc
ept
07:10:43 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: connected
07:10:43 wireless,info 9C:4E:36:D3:84:FC@wlan_guest: disconnected, received disassoc:
paulct
Re: Wireless clients keep getting disconnected/reconnected
Thu Jul 21, 2016 11:25 am
"not in local ACL" should give you a clue
total13
Thu Jul 21, 2016 11:45 am
I have noticed that problem might be in authentication mode, i have created/tested several security profiles with WPA2 PSK, different keys but when it is on, clients get disconnected. It is not wrong setup since it is tested several times and sometimes clients get connected for like 5 minutes but when they start to use connection, create traffic, they get disconnected...
There is no ACL setup on wireless interface....
nichky
Long time Member
Long time Member
Sat Jul 23, 2016 12:15 pm
i've got same problem for log time, im going to show you something, if you fix it up, let me know
http://wiki.mikrotik.com/wiki/Manual:Wi ... Debug_Logs
RouterOS does not have a random function. Many has tried to make script to make random text, but all seems to be flawed.
viewtopic.php?f=9&t=160183
!) Safe Mode is your friend;
jarda
Fri Aug 05, 2016 8:28 am
Have you tried to extend group key update interval to 1hour?
nichky
Long time Member
Long time Member
Fri Aug 05, 2016 12:36 pm
what's that?
jarda
Fri Aug 05, 2016 2:48 pm
Something that might help you.
nichky
Long time Member
Long time Member
Sat Aug 06, 2016 3:56 am
copy that, so how can we set up that?
jarda
Sat Aug 06, 2016 8:38 am
It is a parameter of the security profile.
nichky
Long time Member
Long time Member
Sat Aug 06, 2016 12:08 pm
i've already did,and i let you know after couple of days. Can i ask you which one are you recommending about "Authentication types (im using WPA PSK and WPA2 PSK ) and "Unicast Ciphers (tkip) snd also Group Ciphers (tkip). Just one think Management Protection (allowes)
nichky
Long time Member
Long time Member
Sun Aug 07, 2016 4:06 am
Just i let you know, i've cheange that parametar, but again i've got same problem:
wireless,info xx:xx:xx:xx:xx:xx@wlan_guest: disconnected, ok
07:10:43 wireless,debug wlan_guestxx:xx:xx:xx:xx:x not in local ACL, by default
jarda
Sun Aug 07, 2016 10:54 am
Use wpa2 aes only.
BartoszP
Sun Aug 07, 2016 11:51 am
Are you sure that WiFi credentials are correct for all users' devices ?
The best way is to forgot WiFi lan at each device which has problems and recreate connection.
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
haik01
Mon Aug 08, 2016 11:56 am
That is also my advice. Remove all security profiles, all SSID's etc....
Recreate the new connection (heck, you can even use the Quickset to do this). Use ONLY WPA2-AES. All "modern" equipment can do WPA2.
nichky
Long time Member
Long time Member
Mon Aug 08, 2016 12:47 pm
jarda im having problem again...
j
czolo
Mon Aug 08, 2016 8:49 pm
Change from TKIP to AES
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
nichky
Long time Member
Long time Member
Tue Aug 09, 2016 6:07 am
following that i saw that, whan im connecting mobile phone at that time i've have that problem
wireless,debug wlan2: 94:CE:2C:2C:96:A9 attempts to associate
12:27:32 wireless,debug wlan2: 94:CE:2C:2C:96:A9 not in local ACL, by default accept
and also
09:47:43 wireless,info 84:85:06:49:01:9A@wlan2: disconnected, received disassoc: s
ending station leaving (8)
09:48:01 wireless,debug wlan2: 84:85:06:49:01:9A attempts to associate
09:48:01 wireless,debug wlan2: 84:85:06:49:01:9A not in local ACL, by default accept
Thear mac address from phone
jarda
Tue Aug 09, 2016 7:25 am
What about with aes only, without tkip. I told you that already. And you can disable management protection.
nichky
Long time Member
Long time Member
Wed Aug 10, 2016 3:18 pm
much better, still i can see same problem, at the past was terrible
total13
Tue Jan 24, 2017 6:32 pm
Sorry for delayed answer but, tried factory defaulting device and there were still problems so in the end we bought new device and it solved problems. Although there was issue in that area has lots of neighbouring APs so problems might have gone with transferring more users to 5GHz.
Kind regards
mja
Sun Sep 10, 2017 7:47 pm
Hi there, I was reading this post because I have a similar problem. May I ask that is the difference on allowed management protection enable and the disable management protect, does? what's the difference. Thank you in advance.
harvey
Fri Oct 27, 2017 5:32 pm
I've started having a similar issue here recently, not sure what has changed. I'm running 6.41rc47 with a 2016 Macbook Pro with Touchbar running macOS 10.12.6.
It's described really well here https://wiki.mikrotik.com/wiki/Manual:I ... protection and since disabling it's been fine so far, still early days as I only disabled it about an hour ago but it was happening as often as every 5 minutes before disabling.
arashams
Tue Feb 20, 2018 8:06 pm
I have the exact same issue and the problem still exist.
PacketMangle
Wed Jul 04, 2018 12:35 pm
In case anybody runs across this thread again..
This can be caused by two or more access points operating with the same frequency, SSID and security profile.
The solution is to change each of the AP's to a different frequency.
gigamozg
Tue Jan 21, 2020 9:14 pm
I have two AP in my apartment operating with the same SSID and same security profile but with different frequencies and I experience those issues with constant re-associating/associations for some (but not all) clients (usually, iPhones).
Is there any way how it can be fixed, keeping the same SSID?
Thx in advance!
Corin
Wed Feb 17, 2021 8:03 pm
For those of you that have disconnects, reconnects and reassociations especially ion iOS devices, and i think there are a lot of you since this is an old issue, try this:
My device is RB951G-2HnD and various iOS 13, 14 devices. Before bellow setting all of them were reassociating and generated the log entries which we all know by now.
1. Make sure you are not using an older version of ROS (not less than 6.44.6)
2. Increase key echange interval from 5min to 30min or more.
3. DHCP lease of min 2hours.
4. Band: 2GHz-G/N
5. Channel Width: 20MHz
6. Frequency: Avoid Ch 6 (as it is set by default on many routers) use Ch 1 (2412) or Ch 11 (2462)
and most important
7. Disable AMSDU (Wireless -> HT Tab) and only AMSDU. Leave AMPDU Priorities as is, with 0 checked.
To disable AMSDU enter 0 to AMSDU Limit and AMSDU Treshold.
Also, AMSDU does not work well with noisy wifi environments... (crowded apartment buildings)
YES, i know that disabling AMSDU will decrease your throughput but not as much as you might think.
With above settings I have a N Wifi network with a speed of 8...10MB/s throughput and no reassociations/reconnects.
I'm not saying this will work for everyone but maybe it will work for you as well.
It depends on your use case and needs (max throughput or max connection stability)
mja
Fri Feb 19, 2021 6:11 am
Thank you Corin ^_^
Users browsing this forum: Google [Bot] and 40 guests
