MUM Europe 2020
Yann
Impossible to configure the Metal 2SHPn
Mon Jul 25, 2016 8:03 am
After a first configuration of Metal 2SHPn, winbox displays an error message when I try to see my configuration.
The message is displayed using the address ETH1 or WLAN. No access also via WebFig.
Here is the current behavior of 2SHPn when connected to the PC:
- A power, there is a beep accompanied by a blinking LED first.
- 20 seconds later, all LEDs flash.
- And right after, only the first LED flashes repetitive way.
- The wifi network I created appears.
- Even when I log on to the wireless network that I just created the first LED continues to flash.
My attempts to repair:
I reset as shown in the manual, but the behavior does not change.
Questions:
1- he is describing behavior normal?
2- Are there other possibilities to reset the 2SHPn?
3- Other proposals?
mjsabri
Trainer
Trainer
Re: Impossible to configure the Metal 2SHPn
Mon Jul 25, 2016 8:46 am
you should try connect to Metal 2SHPn by mac address.
Mikrotik Certified Consultant
[ MTCNA , MTCRE , MTCWE , MTCTCE , MTCUME , MTCINE ]
Yann
Mon Jul 25, 2016 10:09 am
I have use Mac address of Eth1 and Wlan, mjsabri, please.
Yann
Mon Jul 25, 2016 10:49 am
There are not something to do on the electronic card to reset the 2SHPn?
Users browsing this forum: No registered users and 18 guests
