azurtem
Trainer
Trainer
Hotspot landing pagedoesn't popup anymore
Tue Jul 26, 2016 8:37 pm
Hi
I'm not sure what I'm doing wrong but the hotspot authentication page (login.html) isn't displayed automatically anymore
The users have to navigate to http://www.google.fr or http://1.1.1.1 to force the login page to show up
Is there a parameter, or more, that I haven't setup properly or is this functionaly no longer operational ?
thanks
yann
mjsabri
Trainer
Trainer
Re: Hotspot landing pagedoesn't popup anymore
Tue Jul 26, 2016 11:03 pm
Hi
if android version is 5 or higher and ios is 9 or higher or windows 8.1 or 10 then login page open automatically but in old operating systems it will not run automatically.
Mikrotik Certified Consultant
[ MTCNA , MTCRE , MTCWE , MTCTCE , MTCUME , MTCINE ]
azurtem
Trainer
Trainer
Wed Jul 27, 2016 7:08 am
Ok, thanks MJSabri
I'm surprised by the OS levels you indicated:
I'm practically certain that this used to work with older OS versions before.
I suppose it must be the newer ROS that has brought about this restriction
mjsabri
Trainer
Trainer
Wed Jul 27, 2016 9:44 am
Hotspot supported in new OS but in old OS you should go to browser and open a website then login page will be load for you.
Users browsing this forum: No registered users and 38 guests
