alessio211734
point to point 160m
Tue Aug 02, 2016 12:03 pm
I should do a link between two houses. The distance is 160 meters in full optical visibility. I should not share the connection but use it only in the destination point link.
I would like create a stable link to allow streaming and download torrent. Can you suggest me a 5ghz mikrotik device to do it?
Thanks in advance.
Ale.
CyberTod
Long time Member
Long time Member
Re: point to point 160m
Tue Aug 02, 2016 2:20 pm
SXT Lite 5 (RBSXT5nDr2) is the device for you.
It will give you 100mbit/s full duplex at the described environment.
If you need more than 100mbit/s - go for RBSXTG-5HPacD
czolo
Tue Aug 02, 2016 9:44 pm
My suggestion is wAP-ac http://routerboard.com/RBwAPG-5HacT2HnD
AC is better than N
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
jarda
Wed Aug 03, 2016 11:10 am
WAP is omnidirectional, not suggestible for ptp link.
czolo
Wed Aug 03, 2016 12:20 pm
Rather sector, from my experience, especially for this distance. SXT has better antenna (panel), but it's not as directional, as it seems
http://i.mt.lv/routerboard/files/sxt-patterns.pdf
But if you have RBwAPG-5HacT2HnD antenna patern, i will see it with pleasure.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
pe1chl
Wed Aug 03, 2016 2:10 pm
It seems you misinterpret the diagrams.... sector is very directional in vertical plane but not in horizontal.
jarda
Wed Aug 03, 2016 2:21 pm
Speed requirements were not stated, but SXT as suggested originally is generally good solution. LHG5 would be good the same (maybe beter) but the question is whether the receiving signal would not be too strong even when tx power will be "overregulated". But it is cheaper than SXT and with narrower beam, so teoretically would be more resistent to interference from surrounding environment. I would try LHG5 or SXT5Lite if 100Mbits/s is enough.
Users browsing this forum: mkx and 16 guests
