MUM Europe 2020
piri
How to setup my MT CPE to connect to a MT in AP Bridge Mode
Fri Oct 06, 2006 11:16 pm
Hi Can anyone help me out here, I have a MT AP in APBridge Mode and are running a hotpsot, all works very well. Clients are using built in wireless to connect to the AP and we are using an external radius server.
I want to add a Wireless Client using a MT Router as the CPE and have it connect to the AP and then use PPPoE to Radius. I am not sure how to set up the Client MT CPE or AP to accomdate my situation.
Can anyone assist me. Basically I want to be able to have hotspot users and PPPoE users on the same AP.
Look forward to any replies HELP.
Regards
P
tneumann
Re: How to setup my MT CPE to connect to a MT in AP Bridge M
Sat Oct 07, 2006 12:26 am
I'd recommend that you configure an additional virtual-AP interface on top of your existing physical AP interface and use the new virtual-AP for PPPoE only. This will give you a clean separation with different interfaces for the hotspot and for PPPoE.
The RouterOS manual describes the setup of both, the virtual-AP and of a PPPoE server in sufficient detail.
--Tom
piri
Sat Oct 07, 2006 4:59 am
Thanks Tom
piri
Sat Oct 07, 2006 6:53 am
Hey Tom
Can you steer me to the right page in the Manual for setting this up. I assume it was setting up an Interface eg Virtual AP ? but I can see where
regards
p
balimore
Forum Veteran
Forum Veteran
Sat Oct 07, 2006 7:45 am
Hey Tom
regards
p
Hello Friend,
Virtual AP same mean as Main wireless interface, also possible to make difference SSID and MAC-Address only.
manual at this link: http://www.mikrotik.com/docs/ros/2.9/in ... t#4.13.9.2
Regards
Hasbullah.com
tneumann
Sat Oct 07, 2006 11:38 am
For PPPoE:
http://www.mikrotik.com/docs/ros/2.9/interface/pppoe
For virtual-AP:
http://www.mikrotik.com/docs/ros/2.9/interface/wireless
--Tom
jo2jo
Forum Veteran
Forum Veteran
Sat Oct 07, 2006 6:37 pm
if your asking about the client side, then set it to the ssid of the AP and set it to station mode...
piri
Mon Oct 09, 2006 11:30 am
Thanks guys your help is much appreciatd
If you lived in New Zealand I would shout you all a beer :)
Regards
Piri
Users browsing this forum: Baidu [Spider], RogerWilco and 36 guests
