MUM Europe 2020
laithmikrotik
mikrotik access point / controlling on the time of wireless authentication
Mon Oct 17, 2016 10:58 am
hi every one ...
i would like from support of the mikrotik factory to read my post and resolve this error in access point rule policy which i found out that when i try to give an limited time to registration with the mikrotik access point
lets us explain the proplem/
suppose you have rb951.you make it as an internet access point .suppose that rb951 is placed in camp , school , college ..Et cetera .the persons in this places have an limited time to connect with the rb951 access point .lets say from 8a.m to 8 p.m evey day .after 8 p.m the persons above have no permissin to connect with rb951 access point unless they must wait to 8 a.m of the next day .
i hope you understood me
lets see the image down
you see tow times/
time 1 = the start time to connect ( the user with mac address listed in access point policy )with the mikrotik access point every day
time 2 = the end time of connecting with the mikrotik access point every day
logically any mac address listed in the policy above can not connect after the time 2
in fact no!!!!!! .
the user with the mac address listed in our example can connect with th rb951 access point even he have no permission to connect .!!
finally .what do you suggest to me another method to carry out my example.please
my greetings
Last edited by laithmikrotik on Wed Oct 19, 2016 10:10 am, edited 2 times in total.
I LIKE MIKROTIK
janisk
Re: post to the support of the mikrotik
Mon Oct 17, 2016 12:03 pm
write to support@mikrotik.com if you want to contact MikroTik support. There are a bit too little information to think about something conclusive.
laithmikrotik
Mon Oct 17, 2016 12:50 pm
thank you very much for your replay . :D
i will do that .but at the same time .i hope anyone can help me to do my post idea ( connecting to any mikrotik access point from time1 to time 2 ) as explained in my post
please help me :(
thanks for all
I LIKE MIKROTIK
janisk
Mon Oct 17, 2016 2:44 pm
what you write, should be doable, however, check timezone settings and check if your router has the time set up properly. Also, check for other entries in that table.
laithmikrotik
Mon Oct 17, 2016 5:49 pm
doable :(
all i want .some one here ( from you and other experts of mikrotik ) to help me to carry out my idea post
by the way idont have any mistake in time setting and others
I LIKE MIKROTIK
jarda
Mon Oct 17, 2016 6:16 pm
"all I want is you to do everything for me". This is not how the things can work in real life.
laithmikrotik
Mon Oct 17, 2016 6:35 pm
all i want is the help .No more, no less
anyway thank you
I LIKE MIKROTIK
Sob
Mon Oct 17, 2016 6:58 pm
That's pretty strong statement. I can believe you about time, that's easy to check. But some settings may be tricky and you didn't tell us much, only about this one rule.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
laithmikrotik
Mon Oct 17, 2016 7:29 pm
here is all my settings
[admin@MikroTik] > export
# oct/17/2016 19:26:49 by RouterOS 6.37.1
# software id = H3GM-P0GM
add name=bridge1
set [ find default-name=ether1 ] name=POE
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=2462 mode=ap-bridge \
    ssid=Z----H-----S-----R
set [ find default=yes ] authentication-types=wpa-psk eap-methods="" mode=dynamic-keys \
    wpa-pre-shared-key=00550055
add name=dhcp_pool1 ranges=25.25.25.2-25.25.25.254
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge1 interface=wlan1
/interface wireless access-list
add interface=wlan1 mac-address=00:23:4D:76:8F:F5 time=8h-20h,sun,mon,tue,wed,thu,fri,sat \
    vlan-mode=no-tag
add address=25.25.25.1/24 interface=bridge1 network=25.25.25.0
/ip arp
add address=25.25.25.4 interface=bridge1 mac-address=00:23:4D:76:8F:F5
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=POE
/ip dhcp-server lease
add address=25.25.25.4 address-lists="" client-id=1:0:23:4d:76:8f:f5 mac-address=\
    00:23:4D:76:8F:F5 server=dhcp1 use-src-mac=yes
add address=25.25.25.0/24 gateway=25.25.25.1
set allow-remote-requests=yes servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=POE protocol=tcp
/system clock
set time-zone-name=Asia/Baghdad
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set POE disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/tool user-manager database
set db-path=user-manager
[admin@MikroTik] >
I LIKE MIKROTIK
andlil
Mon Oct 17, 2016 10:16 pm
On a completely unrelated matter, stop using 25.25.25.0/24 and go for an address in designated space https://en.wikipedia.org/wiki/Private_network
Sob
Mon Oct 17, 2016 11:29 pm
I did quick test here, and when I added access rule for one MAC address, set time limit and connected when it was not allowed, I was still allowed to connect, because of interface's implicit default-authentication=yes. It looks like when the time condition does not match, the whole rule gets skipped, as if it wasn't there at all, and then defaults from interface apply. But that's just my first impression, I'd have to test it some more, plus try current RouterOS version, because this AP doesn't have it. Unfortunately, I don't have much time for it right now.
So make sure your RouterOS is up to date, and if it still happens, document it and ask support if it's a bug or feature.
laithmikrotik
Tue Oct 18, 2016 8:55 am
thank you very much for your interaction with my post :D :D
so .when we set any mikrotik access point rule list with the same policy of my post above .we discover , that the time setting for limitation the users time of connecting with any mikrotik access point is like no effecitive ( no found )
I LIKE MIKROTIK
laithmikrotik
Tue Oct 18, 2016 9:17 am
i do the same scenario on other router board ( rb912 ).
the same proplem
I LIKE MIKROTIK
laithmikrotik
Tue Oct 18, 2016 9:33 am
here is another router board (hAP lite classic RB941 ) .....the same proplem
I LIKE MIKROTIK
karlisi
Tue Oct 18, 2016 10:57 am
Try this
    vlan-mode=no-tag
Karlis
kristaps
Tue Oct 18, 2016 11:05 am
@laithmikrotik please send supout.rif form your router to support@mikrotik.com
laithmikrotik
Tue Oct 18, 2016 11:08 am
Try this
    vlan-mode=no-tag
FAILED
Last edited by laithmikrotik on Tue Oct 18, 2016 11:30 am, edited 1 time in total.
I LIKE MIKROTIK
laithmikrotik
Tue Oct 18, 2016 11:11 am
OK....done
I LIKE MIKROTIK
laithmikrotik
Re: mikrotik access point / controlling on the time of wireless authentication
Thu Oct 20, 2016 10:58 pm
i hope this video will Obtain your satisfaction
its from my personal effort
grettings
https://www.youtube.com/watch?v=8ZOh4NkBayA
I LIKE MIKROTIK
econst
Fri Oct 21, 2016 8:11 pm
Maybe the problem is platform dependent. I have the exact same scenario working on a X86 system(Alix Board) without a Scheduler. Running ROS v6.30.2. Works great.
lambert
Long time Member
Long time Member
Fri Oct 21, 2016 9:59 pm
As a workaround, you could setup a script which enables and disables "/interface wireless access-list" rules to allow or reject users. Then run the appropriate script at the appropriate time.
The key parts would look something like:
/interface wireless access-list enable [find comment~"daytimeuser"]
/interface wireless access-list disable [find comment~"daytimeuser"]
I have not tested or even syntax checked the above. The below wiki pages should help you put it together if you are interested in doing the work.
http://wiki.mikrotik.com/wiki/Manual:System/Scheduler
http://wiki.mikrotik.com/wiki/Manual:Scripting
Users browsing this forum: Bing [Bot], matthramos and 33 guests
