MUM Europe 2020
HellMind
How to configure a WPA2 over a bridge
Thu Oct 12, 2006 7:36 am
Over a station wds --> birdge
Where i should edit the security profile,
I want to set WPA2 and AES, the best encryption.
the manual doesnt show any example with wpa2
sergejs
Thu Oct 12, 2006 8:56 am
Documentation shows how to setup WPA encryption,
http://www.mikrotik.com/docs/ros/2.9/in ... #4.13.21.7
things to change to enable WPA2, 'mode=wpa2-psk', use 'wpa2-pre-shared-key' and 'chiphers=aes-ccm'.
HellMind
Thu Oct 12, 2006 7:13 pm
thank you!
HellMind
Thu Oct 12, 2006 9:17 pm
The new version of routeros
desnt got mode=wpa2psk
Maybe is authentification-type=wpa2psk
I ve create another security profile and I ve configure it to a wlan
is there a way to restart the interface to use the new security profile that i ve set?
HellMind
Thu Oct 12, 2006 11:17 pm
Isnt work
i see the client is registered but notting happens
Something is wrong.
maybe the new routeros got some configuration more to touch to make it work
sergejs
Fri Oct 13, 2006 9:04 am
The latest RouterOS version contains 'authentication-mode=wpa2-psk' (use [Tab] button to check the available commands).
'mode=dynamic-keys' is required together with authentication-mode=wpa2-psk.
'interface wireless set wlan1 security-profile=' (push [Tab] button to see the available security profiles, full information about security-profile 'interface wireless security-profile print'.
Client should have the same authentication options (mode, key etc.) as the access point for successfull communications.
HellMind
Fri Oct 13, 2006 8:56 pm
Then i ll try with dynamic i tryied static,
Where did you learn to configure WPA2?
Why cant be static:S?
HellMind
Fri Oct 13, 2006 9:04 pm
it works
TY!! :D
Im done with this
Users browsing this forum: No registered users and 21 guests
