MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Bursting and Fast Frames
Sun Oct 15, 2006 9:22 am
Hello
In winbox where can I find teh fast-frames feature (reading about in manual)
Also, what is a good setting for burst time?
BrianHiggins
Long time Member
Long time Member
Mon Oct 16, 2006 2:25 am
it's not available in winbox... where are you reading about it? I don't see really anything listed in the manual...
anyone know if it can be used at the same time as nstream (or is it just redundant, or does it actually make things worse?)
Equis
Forum Veteran
Forum Veteran
Mon Oct 16, 2006 2:27 am
I only seen references to it when doing a "print" on the device
BrianHiggins
Long time Member
Long time Member
Mon Oct 16, 2006 3:15 am
http://www.mikrotik.com/docs/ros/2.9/interface/wireless
it is listed there a few times (do a search on the page), but there's nothing really usefull about it.
sten
Forum Veteran
Forum Veteran
Mon Oct 16, 2006 3:26 am
Atheros FastFrames was supported in v2.8 but was removed in v2.9.
It usually gave 1-2 mbit better performance without taxing the cpu as much as nstreme. A feature like FastFrames requires cooperative design with the operating system to be really effective but 1-2 mbit was decent enough for me.
Move along. Nothing to see here.
BrianHiggins
Long time Member
Long time Member
Mon Oct 16, 2006 6:30 am
if it was less intensive then nstream's framer policy, why was it removed?? there are many cases where 1-2mbps would make a big difference, and many cases where the lower CPU load is more important then the extra performace gained by nstream, but you can't cut back on all of the performance...
the ability to use it, or nstream's framer policy (or maybe in conjunction with???) would be usefull to some people I'm sure...
Equis
Forum Veteran
Forum Veteran
Mon Oct 16, 2006 6:57 am
I prefer nstream but in some cases (interference) I can't use nstream so this would be great :-)
Equis
Forum Veteran
Forum Veteran
Mon Oct 16, 2006 6:58 am
Has anyone fiddlied with bursttime in the wireless settings?
what would be a good "us" to start with?
BrianHiggins
Long time Member
Long time Member
Mon Oct 16, 2006 7:11 am
not yet.. I've already got a test for that planned this week, two 5ghz ptp links, -40 to -50 between each side of the link, yet far enough away from each other that opposite links see the other link around -80...
we'll see if the schedule works out... I'll try to remember to post the results in this thread...
BrianHiggins
Long time Member
Long time Member
Mon Oct 16, 2006 3:12 pm
guess it's official...
Fast frames ir removed, so that's why there is no documentation about it. All the ducumentation you can find in the wireless reference manual.
Regards,
Uldis
"Brian Higgins" wrote:
> http://forum.mikrotik.com/viewtopic.php?p=52185#52185
> can you point us to where there some documentation on this feature?? I
> can't find it anywhere...
> thanks
Equis
Forum Veteran
Forum Veteran
Mon Oct 16, 2006 3:16 pm
Ahh well
I guess that had good reason.
I'm looking foward to v3 to see what new goodies the wireless driver will have.
I'm not really after more speed, just better with noise :)
Users browsing this forum: No registered users and 33 guests
