mambotech
wlan not forwarding
Sun Oct 15, 2006 6:56 pm
I am having some issues with a client unit.
current setup: ip address wlan 192.168.2.26
0 R name="wlan1" mtu=1500 mac-address=00:80:48:3C:ED:75 arp=enabled
disable-running-check=no interface-type=Atheros AR5212
radio-name="Asperen CPE" mode=station ssid="MaruCom" area=""
frequency-mode=manual-txpower country=netherlands antenna-gain=0
frequency=2427 band=2.4ghz-b/g scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-b wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
ether1 ip address 192.168.10.1 dhcp server
client ip address 192.168.10.2
C - connect, S - static, r - rip, b - bgp, o - ospf
# DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 ADC 192.168.2.0/24 192.168.2.26 wlan1
1 ADC 192.168.10.0/24 192.168.10.1 ether1
2 A S 0.0.0.0/0 r 192.168.2.7 wlan1
Problem:
I can ping the ethernet address and wlan address from the remote AP
The client can only ping as far as the wlan interface 192.168.2.26.
I have added a nat rule but this makes no difference at all.
I have added a static route on the remote AP but this has not work either.
It looks like the wlan is not forwarding the request from the client only as I can ping out from the router to the remote gateway of 192.168.2.7
Can anyone help please
Thanks Mark :(
juan.gabatel
Same problem
Mon Oct 16, 2006 5:20 pm
Hi, i have the same problem, has 2 vlan non of them make forwarding, i think is the RouterOS, because I have 1 CPE whit RouterOS v 2.9.24 and work very well, now the company has bought 50 CPE, but they come whit RouterOS v2.9.29 and the same configuration doesn’t work, they say to me that I have to upgrade to the last version 2.9.32 to resolve the problem, in fact did it, but now non of the vlan makes forwarding, we are still waiting for a answer of support, but i strongly think that is the RouterOS that make this problem, i want a “routeros-rb500-2.9.24.npk” if someone have it contact me or put the email on the forum so i can contact. Thanks.
Stryker777
Tue Oct 17, 2006 8:49 am
I think I am in agreeance with you both. I have several networks I work on that have been running great and pinging around. Recently I was working one with OSPF configured and could not ping through. I found that if I got on the end point and pinged to an ip addy connected to the main mikrotik, I could then ping from the that address back down to the end point. As long as there was an established connection on the end point for the ip, I could ping. Since there are no rules on the firewall and no nat I thought maybe it was the backhaul units. Unfortunately that was not it. It appears it is in the mikrotik software. They were running .32 on all of theirs. I then upgraded my home network to .32 to test and the same issue occurred.
Established connections from downstream will allow up and down stream pings.
Stryker777
Wed Oct 18, 2006 2:54 am
Here is a question. Could the scope/target scope have something to do with it? Any documentation about these two fields?
Is it
0 Global
255 No Where
254 Link
253 Host
If so, whats the 10, 20 etc that I have seen ?
tgrand
Long time Member
Long time Member
Fri Oct 20, 2006 6:00 pm
Try setting up the CPE on a static address range, and the clients behind it will use DHCP from a DHCP pool.
It works for me
Users browsing this forum: No registered users and 28 guests
