gt4a
capsman band lock fail
Fri Nov 18, 2016 4:46 am
have set band lock to 2g-n only. but not work. tried set band lock in capsman/channels and config. both failed.
is this a bug?
haik01
Re: capsman band lock fail
Fri Nov 18, 2016 10:21 am
Maybe what you see in the WiFi analyzer software, is what the station is CAPABLE to do (in your case b/g/n). It is not showing that the station is PROVIDING the b/g/n service.
Zwodka
Sat Nov 19, 2016 8:48 am
Try this (I use it):
/caps-man channel
add extension-channel=disabled name=Auto/20
add extension-channel=Ce name=Auto/40-Ce
add extension-channel=eC name=Auto/40-eC
add extension-channel=disabled frequency=2412 name=Ch01-2412/20
add extension-channel=Ce frequency=2412 name=Ch01-2412/40-Ce
add extension-channel=disabled frequency=2417 name=Ch02-2417/20
add extension-channel=Ce frequency=2417 name=Ch02-2417/40-Ce
add extension-channel=disabled frequency=2422 name=Ch03-2422/20
add extension-channel=Ce frequency=2422 name=Ch03-2422/40-Ce
add extension-channel=disabled frequency=2427 name=Ch04-2427/20
add extension-channel=Ce frequency=2427 name=Ch04-2427/40-Ce
add extension-channel=disabled frequency=2432 name=Ch05-2432/20
add extension-channel=Ce frequency=2432 name=Ch05-2432/40-Ce
add extension-channel=eC frequency=2432 name=Ch05-2432/40-eC
add extension-channel=disabled frequency=2437 name=Ch06-2437/20
add extension-channel=eC frequency=2437 name=Ch06-2437/40-eC
add extension-channel=Ce frequency=2437 name=Ch06-2437/40-Ce
add extension-channel=disabled frequency=2442 name=Ch07-2442/20
add extension-channel=eC frequency=2442 name=Ch07-2442/40-eC
add extension-channel=Ce frequency=2442 name=Ch07-2442/40-Ce
add extension-channel=disabled frequency=2447 name=Ch08-2447/20
add extension-channel=eC frequency=2447 name=Ch08-2447/40-eC
add extension-channel=Ce frequency=2447 name=Ch08-2447/40-Ce
add extension-channel=disabled frequency=2452 name=Ch09-2452/20
add extension-channel=Ce frequency=2452 name=Ch09-2452/40-Ce
add extension-channel=eC frequency=2452 name=Ch09-2452/40-eC
add extension-channel=disabled frequency=2457 name=Ch10-2457/20
add extension-channel=eC frequency=2457 name=Ch10-2457/40-eC
add extension-channel=disabled frequency=2462 name=Ch11-2462/20
add extension-channel=eC frequency=2462 name=Ch11-2462/40-eC
add extension-channel=disabled frequency=2467 name=Ch12-2467/20
add extension-channel=eC frequency=2467 name=Ch12-2467/40-eC
add extension-channel=disabled frequency=2472 name=Ch13-2472/20
add extension-channel=eC frequency=2472 name=Ch13-2472/40-eC
Select a channel/frequency, after that choose a band: 2ghz-g/n or 2ghz-onlyn.
gt4a
Mon Nov 21, 2016 3:57 am
/caps-man channel
thanks, but I would prefer auto frequency.
stick to a fix frequency may not be a good idea for me. there are toooo many 2.4G APS nearby. (more than 50 AP, and 50+ IOT wifi). channel sucks.
Users browsing this forum: No registered users and 25 guests
