OKNET
CAPsMan question
Fri Dec 02, 2016 3:38 pm
Does CAP system dynamically manage power level and frequency of each controlled AP like other systems do ?
BartoszP
Re: CAPsMan question
Fri Dec 02, 2016 5:21 pm
I'm not sure about power level but if you do not set fequency then CAPsman interfaces behave as set to "auto"
Real admins use real keyboards.
nickshore
Fri Dec 02, 2016 6:17 pm
Power level is managed using the antenna gain setting on wireless settings of the AP, and the region setting in capsman.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
OKNET
Mon Dec 05, 2016 9:25 am
I mean, does CAP system analyze wireless environment then, accordingly, manage itself dynamically channels and power levels for best performance ?
Or is it only a Centralized CONFIGURATION controller (to be tuned by installer only once) ?
Users browsing this forum: Google [Bot] and 32 guests
