nleistad
CAPsMAN supports only FIRST client
Wed Dec 14, 2016 11:18 pm
I THOUGHT I had CAPsMAN configured correctly. No complaints when configuring.
Added CAPs-bridge to attach the CAPs, added IP to CAPs-bridge, added CAPs-dhcp-server to assign addresses
Have Access Lists::Security Config::Datapaths::Configurations::Provisioning.
Enable CAPsMAN manager, convert wlan1 to CAP, attach additional wlan devices (wAP); they all join.
Connect first device, will auto switch between APs, surfs, NetFlix app plays content, can disable connected AP, auto switch to other. Re-provision, disable connected AP, auto switch back, continues streaming content.
Add a SECOND device, gets address, can ping gateway, no joy beyond that. Shows "No Internet Connection", can't ping, can't surf, " Network not reachable..."
Disconnected first device, reconnected second device, still no joy on second device (now only connected device).
What have I done incorrectly? Don't understand why first device flawless, subsequent devices have nothing. Almost like missing a route?
WAN - dhcp-client
LAN-bridge - 192.168.88.1/24
CAPs-bridge - 10.10.10.1/24
Tried w/ and w/o local-forwarding.
olkitu
Re: CAPsMAN supports only FIRST client
Fri Dec 23, 2016 2:44 pm
Please post your all configuration. Seems very strange. Do you have DHCP configured correctly or ARP issue? Try clear ARP on Mikrotik router so then you can ping?
Client get IP address from DHCP? Can client 2 ping to client 1???
Network Specialist
Need know where is cellular tower? Try CellMapper to get know where is cellular tower:
https://www.cellmapper.net/map
nleistad
Tue Jan 17, 2017 1:07 am
I got frustrated w/ the configuration. deleted, re-entered, Identically as far as I could tell....started working. ODD.
Users browsing this forum: No registered users and 57 guests
