Wyz4k
HWMP+ Mesh network preferring Wlan over Ethernet (incorrectly)
Wed Jan 25, 2017 7:42 am
Hi there,
I have a working dynamic mesh between three devices over WLAN. But as this mesh could become a lot bigger I would like to have the flexibility of using ethernet links between some devices to reduce wireless usage / interference etc.
However when I add the ether1 interface to the mesh, it still sends the traffic over the wlan instead of over the ethernet. According to the wiki HWMP+ is suppose to support ethernet in the mesh.
What I've noticed:
1) the other routers ethernet ports are shown as outsiders in the Mesh FDB. They should be included in the mesh as they've been added to the mesh on both sides. The sequence number does not increase for ether1. For other interfaces the sequence numbers do increase.
2) Active type in Mesh Port for ether1 is ethernet bridge and not ethernet-mesh like I would expect. How can I change it to ethernet-mesh? The port type is set to auto and I have verified that it's not included in the bridge.
3) If I disable the WLAN manually it immediately starts using the Ethernet and there is no interruption in the connection. This leads me to believe that the Ethernet is correctly configured as part of the mesh.
I've tried:
1) firmware 6.35.1, 6.37.1 and 6.38, and they both show the same behaviour. I can't go back further than 6.35.1 due to that being the minimum ROS version for my hardware.
2) dropping the cost of ether1 in MeshPort to 0, and increasing the cost to 100. This does not appear to have any effect.
3) using an admin-mac for the mesh so that the other devices don't see a change in MAC when switching between wlan and ethernet.
4) I've tried enabling and disabling reoptimize paths.
5) I've tried enabling and disabling mesh portal to switch between proactive and reactive.
6) Rebooting all devices after making changes to clear out any residuals.
Router1 Mesh:
[admin@192.168.8.2] /interface mesh> print detail
 0  R name="MeshNetwork" mtu=1500 arp=enabled arp-timeout=auto mac-address=6C:3B:6B:22:02:F3 auto-mac=yes
      admin-mac=30:F6:B9:00:00:A2 mesh-portal=no hwmp-default-hoplimit=32 hwmp-preq-waiting-time=4s hwmp-preq-retries=2
      hwmp-preq-destination-only=yes hwmp-preq-reply-and-forward=yes hwmp-prep-lifetime=5m hwmp-rann-interval=10s
      hwmp-rann-propagation-delay=0.5 hwmp-rann-lifetime=22s reoptimize-paths=no
Router1 Mesh port:
[admin@192.168.8.2] /interface mesh port> print detail
Flags: X - disabled, I - inactive, D - dynamic
 0    interface=wlan1 mesh=MeshNetwork path-cost=10 hello-interval=10s
      port-type=auto active-port-type=wireless
 1    interface=ether1 mesh=MeshNetwork path-cost=1 hello-interval=10s
      port-type=auto active-port-type=ethernet-bridge
 2  D interface=wds2 mesh=MeshNetwork path-cost=100 hello-interval=10s
      port-type=auto active-port-type=WDS
 3  D interface=wds3 mesh=MeshNetwork path-cost=100 hello-interval=10s
Router1 Mesh FDB:
[admin@192.168.8.2] /interface mesh fdb> print detail
Flags: A - active, R - root
 AR mesh=MeshNetwork type=mesh mac-address=30:F6:B9:00:00:A4 on-interface=wds3 lifetime=0s age=4s metric=100 seq-number=337
 A  mesh=MeshNetwork type=local mac-address=6C:3B:6B:22:02:F3 age=3m6s metric=0 seq-number=22
 A  mesh=MeshNetwork type=local mac-address=6C:3B:6B:22:02:F5 age=3m6s metric=0 seq-number=22
 A  mesh=MeshNetwork type=outsider mac-address=6C:3B:6B:22:02:F6 on-interface=ether1 lifetime=0s age=2m56s metric=1 seq-number=0
 A  mesh=MeshNetwork type=neighbor mac-address=6C:3B:6B:22:02:F8 on-interface=wds2 age=3m6s metric=100 seq-number=20
 A  mesh=MeshNetwork type=neighbor mac-address=6C:3B:6B:74:43:FE on-interface=wds3 age=3m6s metric=100 seq-number=338
Router1 Ethernet:
Router1 Wlan:
[admin@192.168.8.2] /interface wireless> print detail
 0  R name="wlan1" mtu=1500 l2mtu=1600 mac-address=6C:3B:6B:22:02:F5 arp=enabled interface-type=Atheros AR9888 mode=ap-bridge
      ssid="WifiV1" frequency=5180 band=5ghz-a/n/ac channel-width=20mhz scan-list=default
      wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=dynamic-mesh wds-default-bridge=MeshNetwork wds-ignore-ssid=no
      bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=Security compression=yes
Router2 Mesh:
[admin@192.168.8.1] /interface mesh> print detail
      mac-address=6C:3B:6B:22:02:F6 auto-mac=yes admin-mac=30:F6:B9:00:00:A1
      hwmp-preq-retries=2 hwmp-preq-destination-only=yes
Router2 Mesh port:
[admin@192.168.8.1] /interface mesh port> print detail
 0    interface=wlan1 mesh=MeshNetwork path-cost=10 hello-interval=10s port-type=auto
 1    interface=ether1 mesh=MeshNetwork path-cost=1 hello-interval=10s port-type=auto
 2  D interface=wds3 mesh=MeshNetwork path-cost=100 hello-interval=10s port-type=auto
 3  D interface=wds4 mesh=MeshNetwork path-cost=100 hello-interval=10s port-type=auto
Router2 Mesh FDB:
[admin@192.168.8.1] /interface mesh fdb> print detail
     lifetime=0s age=6s metric=100 seq-number=35
 A  mesh=MeshNetwork type=outsider mac-address=6C:3B:6B:22:02:F3 on-interface=ether1
     lifetime=0s age=17m7s metric=1 seq-number=0
 A  mesh=MeshNetwork type=neighbor mac-address=6C:3B:6B:22:02:F5 on-interface=wds4
     age=17m8s metric=100 seq-number=102
 A  mesh=MeshNetwork type=local mac-address=6C:3B:6B:22:02:F6 age=17m8s metric=0
     seq-number=100
 A  mesh=MeshNetwork type=local mac-address=6C:3B:6B:22:02:F8 age=17m8s metric=0
     seq-number=100
     age=17m8s metric=100 seq-number=36
Router2 Ethernet:
[admin@192.168.8.1] /interface ethernet> print detail
Flags: X - disabled, R - running, S - slave
 0 RS name="ether1" default-name="ether1" mtu=1500 l2mtu=1600
      mac-address=6C:3B:6B:22:02:F6 orig-mac-address=6C:3B:6B:22:02:F6 arp=enabled
      arp-timeout=auto loop-protect=default loop-protect-status=off
      loop-protect-send-interval=5s loop-protect-disable-time=5m auto-negotiation=yes
      advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
      full-duplex=yes tx-flow-control=off rx-flow-control=off speed=100Mbps
      master-port=none bandwidth=unlimited/unlimited
Router2 Wlan:
[admin@192.168.8.1] /interface wireless> print detail
 0  R name="wlan1" mtu=1500 l2mtu=1600 mac-address=6C:3B:6B:22:02:F8 arp=enabled
      interface-type=Atheros AR9888 mode=ap-bridge ssid="WifiV1" frequency=5180
      wds-default-bridge=MeshNetwork wds-ignore-ssid=no bridge-mode=enabled
      default-client-tx-limit=0 hide-ssid=no security-profile=Security
      compression=yes
Update:
A third router that is only connected to the mesh over WLAN can see the ethernet address of the router1 as being in the mesh.
[admin@192.168.8.4] /interface mesh fdb> print detail
 A  mesh=MeshNetwork type=local mac-address=30:F6:B9:00:00:A4 age=25m36s metric=0 seq-number=155
 A  mesh=MeshNetwork type=mesh mac-address=6C:3B:6B:22:02:F3 on-interface=wds2 lifetime=0s age=11m17s
     metric=101 seq-number=0
 A  mesh=MeshNetwork type=mesh mac-address=6C:3B:6B:22:02:F6 on-interface=wds2 lifetime=0s age=5s
     metric=100 seq-number=219
 A  mesh=MeshNetwork type=neighbor mac-address=6C:3B:6B:22:02:F8 on-interface=wds2 age=25m36s
     metric=100 seq-number=220
 A  mesh=MeshNetwork type=local mac-address=6C:3B:6B:74:43:FC age=25m36s metric=0 seq-number=155
 A  mesh=MeshNetwork type=local mac-address=6C:3B:6B:74:43:FE age=25m36s metric=0 seq-number=155
So after all that, the question is what do I have to change in the above configuration to have the routers in question prefer ethernet over WLAN when ethernet is available? It should in my opinion just be a function of the cost, but it isn't at the moment... bug or something missing?
Thanks in advance!
syadnom
Re: HWMP+ Mesh network preferring Wlan over Ethernet (incorrectly)
Sat Oct 19, 2019 1:58 am
Just popped in for a similar post, same issue. Did you ever find a resolution?
Wyz4k
Tue Oct 22, 2019 6:17 am
Afraid not. It seems that there aren't many people using the Mesh functionality but unfortunately it is a critical requirement to us. So we are just working around the issues at the moment.
syadnom
Tue Oct 22, 2019 7:00 am
I figured it out, set the Ethernet as WDS.
Wyz4k
Tue Oct 22, 2019 7:05 am
Nice! Will give it a try.
vecernik87
Long time Member
Long time Member
Wed Oct 23, 2019 1:18 pm
Great idea! switching to WDS helped, but I guess this is some bug in implementation
Wyz4k
Thu Oct 24, 2019 5:42 am
By the way, not sure if you guys are using the neighbor broadcast with mesh but there are some issues that's preventing us from using the latest version: viewtopic.php?f=2&t=150330
Users browsing this forum: No registered users and 31 guests
