I am not able to replicate thisI think that MU-MIMO hype is overrated, you can find lots of information about this on the net,
How are you trying and what happens?I am not able to replicate thisI think that MU-MIMO hype is overrated, you can find lots of information about this on the net,
http://community.cambiumnetworks.com/t5 ... td-p/67561
in my lab with using mikrotik
Ahh, Mikrotik is more comparable to the Cambium ePMP 1000, e.g. they both use Qualcomm-Atheros silicon.I am not able to replicate thisI think that MU-MIMO hype is overrated, you can find lots of information about this on the net,
LOLAhh, Mikrotik is more comparable to the Cambium ePMP 1000, e.g. they both use Qualcomm-Atheros silicon.I am not able to replicate thisI think that MU-MIMO hype is overrated, you can find lots of information about this on the net,
The PMP450m uses custom FPGA's and proprietary beam forming technology, is much more advanced than the commodity chipset based stuff, and is priced as such...
You cannot expect Ferrari performance with a Yugo price
Many months on and still not available mikrotik CPE & cambium firmware, as always don't believe product predictions from sales.LOL
Cant compare vs Cambium ePMP 1000/2000 because cambium have TDD 75:25 ratio & this TDMA WORKS for 50 CPE units easy.
Mikrotik TDMA NV2 TDD 50/50 only & max20-30 stations. For new 6.8 MIkrotik NV2 useless , only pure 802.11N can gave 50% wifi real speed.
But soon we can use mikrotik CPE & cambium firmware http://www.cambiumnetworks.com/products ... p-elevate/
Update to 6.40xMany months on and still not available mikrotik CPE & cambium firmware, as always don't believe product predictions from sales.LOL
Which work well ?
Update to 6.40x
You can change the duty cycle on AP Side with:
-nv2-downlink ratio=80 (making all CPE 80% download + 20% Upload)
-nv2-mode=
--Options:
---- dynamic-downlink --fixed-downlink -- sync-master and sync-slave..
Works very well, im using 6.40.5
REgards
Two years...in the 6.41rc there's a new feature
!) wireless - new driver with initial support for 160 and 80+80 MHz channel width;
and indeed MT will have its first wave2 device, the next gen cAP with IPQ4018 (https://www.qualcomm.com/products/ipq4018) that has mu-mimo support in hw.
the device received FCC approval and it is called cAPG-5HacD2HnD.
so mu-mimo might be not too far away for indoors.
And nothing...Two years...
wait for Ros 7And nothing...Two years...
Four more years...wait for Ros 7And nothing...Two years...
lol
Most of the features are implemented, but MU-MIMO is WIPWhat is the current status of wave 2 features in Mikrotik wireless drivers?
Any validity of the statement?Nothing changed
6.41rc support AR9888 chipset?in the 6.41rc there's a new feature
Noin the 6.41rc there's a new feature
Do you have any information?
