MUM Europe 2020
Hydro
R52
Tue Oct 31, 2006 2:44 pm
I can't seem to get an answer for this.
When R52 is set to a 5 or 10 mhz channel does it listen on the same 5 or 10 mhz channel? Or is it like the CM9 and listens on a larger channel?
Hydro
Hydro
Wed Nov 01, 2006 7:09 am
What will it take to get this answered?
Hydro
Equis
Forum Veteran
Forum Veteran
Wed Nov 01, 2006 1:24 pm
I have read (on this forum) that the r52 does indeed listen on 5/10mhz channels and cm9 ill only listen on 20mhz.
I cannot say for sure vut I have read it a few times.
It would be best if teh Manuafacture jump in and answer?
Hydro
Thu Nov 02, 2006 1:58 am
From searching the forums it seems the manufacture always avoids answering this question. So to me that means it must be worse than the CM9.
Hydro
normis
Thu Nov 02, 2006 12:29 pm
we simply don't have this information, as this feature (5/10Mhz) is unofficial and not documented. Is there even a way to test this?
Equis
Forum Veteran
Forum Veteran
Thu Nov 02, 2006 11:58 pm
I guess when one of us gets time, but a couple in a rb with close channels and speed test
Then to same with cm9
Wavelan
Fri Nov 03, 2006 4:43 am
I can't speak for R52, but i can speak for CM9.
CM9 (and all AR-5213) could :
- Transmit & Receive at : 20 & 40 Mhz
- Transmit at 5,10,20 Mhz, but receive at 20 Mhz.
How to test ?
Simple, get a few RB :
- Mode 5 Ghz : scan
- Mode 5 Ghz : 10 mhz -> scan
- Mode 5 Ghz : 5 mhz -> scan
High Regards,
Andrei
Users browsing this forum: No registered users and 26 guests
