crond
need wireless expert (trainer) for fix my wireless problems
Mon Feb 20, 2017 10:33 am
hello
my admin gone and i need wireless expert (trainer) to fix my wireless problems.
my mail: kostas@terabyte.gr
thanks
Quared
Trainer
Trainer
Re: need wireless expert (trainer) for fix my wireless problems
Tue Feb 21, 2017 2:30 pm
very poor info, what has happened and what you'd need a consultant for ?
Check consultants' section on mikrotik.com to find your nearest one also able to support you in your language
greets
jarda
Tue Feb 21, 2017 3:42 pm
Describe your problem in details. We will try to help you or offer individual consultancy if necessary.
laikar
Tue Feb 21, 2017 7:49 pm
Hey Jarda, I need ur favour
Actually I'm using as a access point Netmetal 5 with Ubiquiti 19dbi 120 degree sector antena, using SXT lite 5 for Client CPE.
Now my problem is within 1km area I got very low signal like -77/-72 some time -65/-67 I dnt know is that ok? Or some thing wrong with my configuration
Imageuploading images
dadoremix
Tue Feb 21, 2017 9:50 pm
Ccq is very very low
7/3 %
Not working?
Sent from my iPhone using Tapatalk Pro
jarda
Sun Feb 26, 2017 9:34 pm
It must be bad alignment or bad power settings. Check the chains. Maybe try 802.11 instead of nv2. Whatever can be broken.
crond
Mon Feb 27, 2017 12:36 pm
im a wisp and my admin has gone.
i need a very good wireless expert or trainer to fix my wireless connections on my backbone
all my products are mikrotik with latest firmware and version bugfix
haik01
Mon Mar 06, 2017 12:16 am
You asked that question a week ago, and some people asked you to describe your problems. What can you do, or what can you not do?
it is the same that you bring you broken car to the garage, and tell the mechanic: "that car is broken, please fix it".... Guess what his first question will be......
jarda
Mon Mar 06, 2017 10:29 am
Hire a new admin or sell your network.
Users browsing this forum: No registered users and 17 guests
