TedjeVanEs
Huawei E3372 LTE modem not found - SOLVED
Mon Feb 20, 2017 10:37 pm
I want to use a Huawei E3372 LTE modem as failover when my wired internet fails. I purchased an unlocked E3372, because it is supposed to be compatible with Router OS on my RB951G-2HnD. Stick is working when plugged into a macbook. PIN disabled and APN setup correctly.
When I insert the stick into the USB port of the router, not much happens. No LTE interface is created.
Resources - USB shows
Device 1:5
Vendor HUAWEI_MOBILE
Name HUAWEI_MOBILE
Serial Number
Vendor ID 0x12d1
Device ID 0x14dc
Speed 480 Mbps
USB Version 2.10
Ports 0
What do I need to do to make the router recognize the LTE modem?
In love with RB951G-2HnD, but she's not easy to please
Aufan388
Re: Huawei E3372 LTE modem not found
Tue Feb 21, 2017 4:17 pm
Have you tried change what I have in the photo? I had to do this for a mini-pcie LTE modem to get it to recognize the interface
ALSO, do you have the LTE package installed on the router? Check in system packages, you might have to download it in "all packages" RouterOS version for your OS version.
TedjeVanEs
Tue Feb 21, 2017 6:16 pm
tnx. I just checked. Seems I don't even have that USB button under system - routerboard (pic removed, showed serial)
I also don't see the LTE package in the list. How and where should I download that? (see attached pic)
Aufan388
Tue Feb 21, 2017 6:59 pm
Ok, then you simply don't have the package installed :)
Go download and install the LTE package from https://mikrotik.com/download (see pictures). Unzip the file, drag & drop (ignore the version type on my screenshot) it in winbox, and then reboot. Should work after that.
Better to update all to 6.38.1, as well so that all packages/ system are the same version. Just leave out the packages you don't need....like gps, lcd ..ect ;)
TedjeVanEs
Tue Feb 21, 2017 9:56 pm
tnx, I installed the lte package, and while at it, upgraded all packages to 6.38.1
Rebooted with high hopes, but still not showing under interfaces. Any other extra package I might need?
[edit:] Also tried to powercycle, but still no lte interface. I could try to find a powered USB hub, to rule out any power issues although specs of E3372 say: 3.5W Power supply 5V/500mA
Aufan388
Tue Feb 21, 2017 10:55 pm
I forgot that usb works differently, you need to create a ppp-out interface and add the APN and pin to that. I normally use SXt LTE and mini-pcie setups :P
You can watch the video from the link below in Spanish but you will see what he does. The main info is in the first 10 min of the video. This should work after this.
https://www.youtube.com/watch?v=j-rCEKG8408
TedjeVanEs
Wed Feb 22, 2017 2:59 am
According to http://wiki.mikrotik.com/wiki/Supported ... and_modems the Huawei E3372 should work with the LTE interface, not necessary ppp. Although the latter doesn't show up either.
From everything I have found and seen so far, I was expecting the LTE to show up under interfaces, after sticking in the USB... But alas, not today :(
Can someone from Mikrotik chime in please?
TedjeVanEs
Tue Feb 28, 2017 5:57 pm
The great guys at Mikrotik helped me. For future reference the solution:
System-Ports-Firmware
set ignore-directip-modem=no
pe1chl
Tue Feb 28, 2017 8:31 pm
What is that package for? My E3372 works without that (in LTE mode).
Does it offer extra monitoring or configurability?
pe1chl
Tue Feb 28, 2017 8:32 pm
After doing this, do you get the external IP on the LTE interface? Or still the 192.168.8.x network?
Aufan388
Wed Mar 01, 2017 9:50 am
I could be wrong, but I believe it is needed for boards that have the sim slot on them or when a mini pci-e LTE modem is attached so that you can add in the APN, which LTE band, and so on. No much more is offered for monitoring , that I see, but then of course I only use it enough so that it works.
pe1chl
Re: Huawei E3372 LTE modem not found - SOLVED
Wed Mar 01, 2017 2:02 pm
Likely the LTE package is only required for PCI LTE cards and not for USB devices (that have all the LTE specific processing already onboard).
The E3372 can operate in 3 modes:
- as a PPP (serial) modem
- as a network device with NAT and a webpage, 192.168.8.x network
- as a transparent network device
The latter is unfortunately not yet supported in RouterOS. Usually the E3372 will be in the second mode and
will appear as a network device with lte1 name on which you only have to put a DHCP client.
RAFL
Sun Apr 15, 2018 12:38 am
How can I switch E3372 to work as PPP (serial) modem.
pe1chl
Mon Apr 16, 2018 9:14 pm
Search for it on the internet. It is a complicated procedure, you need to hack the device and flash different firmware. Not some easy parameter setting, unfortunately.
juliokato
Mon Apr 16, 2018 9:28 pm
You need to be lucky and find a seller who has the product not hilink. I have a airtel 4G product which I converted to hilink, just the opposite of what you want.
Find the model: Airtel E3372H-607
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
womentake
Mon Apr 16, 2018 10:06 pm
I have been getting the same error, I downloaded package from https://mikrotik.com/download now all seems fine! Thank you guys.
Cheers,womentake.
mlenhart
Tue Apr 17, 2018 2:40 pm
If you need E3372 which works as PPP modem, I can sell you as much as you want :D
I am looking for the opposite, E3372 which works as native LTE interface :)
antasena
Mon Dec 03, 2018 9:56 am
Please be upgrade the firmware, and also set the network as 3G/HSPA+ if your LTE network only shown 2-3 Bar
Users browsing this forum: Baidu [Spider], Google [Bot], heidarren and 16 guests
