normis
240Km link with RB532 @ 20Mbits
Fri Nov 10, 2006 9:35 am
Kemal from cyprus.com has completed his 240Km link to Lebanon. More information:
Thanks!!!
We established a 244km p2p 5ghz link!!! Thanks for this product
Signal is -65 and rock solid!!!
We are at Cyprus. both sides at more than 800 meters above the sea level.
We used 1.2 meters dish sr2 for 2.4Ghz : signal is -67 and stable... we have more than 10 days link uptime. We used RB532.
With Nstream enabled we had approx. 20mbits oneway. I believe with pc it will be much and much more...
Pings : minimum : 8ms, Max : 21ms
Ill send you 5ghz result after this week.
macgaiver
Fri Nov 10, 2006 10:37 am
I was skeptical, so i took a deeper look:
Nr1) SR2 = tx power 400mW
Nr2) RX sensitivity at band 36Mbps (topic said that it was 20Mbps link so the air-rate should be 36Mbps at least) for SR2 = -83
Nr3) 1.2 meters dish - if i'm not mistaken it is about 35dBi
Nr4) there must at least half meter of cable between antenna and RB532
Nr5) there are no big difference in frequency settings we can choose any - 2412 MHz
I tried several link calculators including this:
http://www.mikrotik.com/test_link.php
My results:
it is theoretically possible to have signal level of - 47 at 130km
it is theoretically possible to have signal level of - 48 at 145km
it is theoretically possible to have signal level of - 49 at 160Km
so, -65 at 244Km, hmmm
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
macgaiver
Fri Nov 10, 2006 10:40 am
Some questions -
could you inform us about CCQ of the link and ping time???
tgrand
Long time Member
Long time Member
Fri Nov 10, 2006 2:56 pm
Highest transmitted frequency : 5810.000 MHz (5.810 GHz)
Wavelength : 2.031 inches (5.160 centimeters)
Transmitter RF power output : 26.000 dBm (398.107 milliwatts)
Transmit cable type : Times Microwave LMR-600
Transmit cable length : 1.640 feet (0.500 meters)
Total transmit cable loss : 0.119 dB (0.073 dB/foot 0.238 dB/meter)
Total transmit connector loss : 0.500 dB through 2 connectors
Total transmit cable loss : 0.619 dB
Transmit miscellaneous losses : 1.000 dB
Transmit antenna peak gain : 35 dBi
RF input power to the antenna : 25.381 dBm (345.223 milliwatts)
Allowed input power to antenna : 20.333 dBm (107.969 milliwatts) Per FCC Part 15 rules
Transmit antenna height : 2624.672 feet (800.000 meters)
Distance to the radio horizon : 70.300 miles (113.137 kilometers)
Receive cable type : Times Microwave LMR-400
Receive cable length : 1.640 feet (0.500 meters)
Total receive cable loss : 0.178 dB (0.108 dB/foot 0.355 dB/meter)
Total receive connector loss : 0.500 dB through 2 connectors
Total receive cable loss : 0.678 dB
Receive miscellaneous losses : 1.000 dB
Receive antenna peak gain : 35 dBi
Receive antenna height : 2624.672 feet (800.000 meters)
Received power level : -61.778 dBm (182.211 µV)
Receiver's threshold : -82.000 dBm (17.762 µV)
Thermal fade margin : 20.222 dB Very good link.
Probability of outage : 0.1 %
Total free space path loss : 155.481 dBi over a path length of 151.615 miles (244.000 kilometers)
Peak transmitted EIRP : 59.381 dBm (867124.763 mW) This power output violates current FCC rules for point to multipoint links.
Midpoint 0.6 Fresnel zone boundary : 142.539 feet (43.446 meters)
Maximum space wave communications distance : 140.600 miles (226.274 kilometers)
tgrand
Long time Member
Long time Member
Fri Nov 10, 2006 3:11 pm
From my calculation above it is very possible.
His result of -65 shows an additional loss of 4 dBi over my calculation of -61.
His Heights are what make all the difference.
800 meters is very high, and over water would indicate very little interference sources.
Congrats Kemal !!!!
mipland
Fri Nov 10, 2006 7:15 pm
What about your ack-timeout?
Are you able to made the link without nstreme (nstreme bypass the ack-timeout limitation that, if I'm not in wrong, is of 409us for Atheros 5213)?
Bye
IZ3HAD, Mirco
aviper
Fri Nov 10, 2006 10:28 pm
DAAAAMN GOOOD WORK :).
matthias
Sat Nov 11, 2006 9:58 pm
congratulations...
hmm - sorry for the maybe stupid question, but are you really allowed to do such a high output power in your country??
I´m only allowed to do 1000mw (30db) her - so no possibility to do such a link :lol:
mipland
Wed Nov 15, 2006 2:25 pm
Bye
IZ3HAD, Mirco
ayzanet
answers to questions asked.
Mon Nov 20, 2006 2:40 am
to mipland: link is NOT possible without nstreme as it was continously connecting/disconnecting due to ack problem.
to matthias: we have rules here that allows us 2W eirp for p2mp links but they dont cover p2p links. We are trying to explain to prehistoric minds in our government that we are in export business now but they are having hard time understanding how we can export something that you cant touch.
macgiver: below is average ping times when there was approx 2mbits passing through the link.
100 packets transmitted, 100 packets received, 0% packet loss
round-trip min/avg/max = 5/10.2/35 ms
with this traffic TX/RX CCQ is almost always at 100/100
I must say that we were very skeptical of any link of this magnitude as well, but guess what, it works!
anyone in egypt want to shoot for a 500km link? naah :lol:
Kemal
mipland
Re: answers to questions asked.
Mon Nov 20, 2006 2:49 am
Thanks Kemal, this
is very important for me. I had the same issues with a 112km link: succesfully connection for about 1-2 seconds, then disconnect, then succesfully connection for 1-2 sec. then disconnect and so on... and your answer is the confirms my doubt!
Thanks again
Bye
IZ3HAD, Mirco
GWISA-Kroonstad
Fri Nov 24, 2006 11:08 am
Excellent Work!
Lebanon and Cyprus, both Small but effective countries. I feel proud.
Thank You Mikrotik.
Cheers.
mojiro
Fri Nov 24, 2006 2:25 pm
Excellent.
What are its country's EIRP Limitations without licence ?
nickb
Mon Nov 27, 2006 8:30 pm
please post a radio mobile archive with the network so that we can drool over the pretty pictures :)
normis
Tue Nov 28, 2006 8:48 am
it was in the other topic i think
GWISA-Kroonstad
Wed Nov 29, 2006 4:12 pm
Where exactly in Lebanon? How far inland? Shouldn't be far coz Mountains go straight into the sea in most Lebanon.
soleed
Wed Nov 29, 2006 9:21 pm
Kemal
GOOD JOB ,
i think we must try a link to TRIPOLI : ) in lebanon i have a hight point here i use it as HOTSPOT point to cover all North Lebanon Plan,
Maybe we will try to communicate .
hdhruv
Sat Jan 06, 2007 5:55 am
what is the thoughput you are getting on this link in terms of MB? I suggest if possible,try putting up an FTP server one side and ftp cleint on other side and transfer so big file so that you get the actual stats of througput
onowojemma
Sat Jan 06, 2007 9:51 pm
Good work thanks for the work can u please past your configuration and the names for the equipment that you use?
Mikrotik! making networking easy
NetTraptor
Fri Jan 12, 2007 2:12 pm
Can you do some pictures of the setup?
Are the feeders you used hand made?
I am interested in general to see how people there in Cyprus do their stuff.
Here are some pics from various more or less important nodes of our network.
http://info.awmn.net/users/cpg/index.php?cat=2&page=1
Here is one we did a while ago... not as long but very critical as it bonds 2 distant and remote places around athens ... I believe that we had loads of other attempts and successes from other people in our community..
http://info.awmn.net/users/cpg/thumbnails.php?album=140
http://wind.awmn.net/?page=nodes&node=6 ... ng=english
Has anybody of you tried setting up solar panels, wind generators or something similar to power those boards in remote places? we are looking into it since this is our main problem for links like these...power..
Lots more are to come given the weather and the timing is good :D
odie
Fri Jan 12, 2007 6:03 pm
we did some locations with solar power only
is a bit of calculating - how long do you want the hardware to run on bad weather - what is the wattage of the hardware ?
do you want to to add more hardware in future ?
in addition with a wind generator and in a windy location you can save money for battries ...
skynoc
Sun Jan 14, 2007 12:48 pm
good work mikrotik ,we are working on the same project from tripoli to cyprus .
more qiestions on the way
bokad
Wed Jan 17, 2007 3:53 am
Is there any reason this couldn't be done to longer distances? Say 300 miles? Radiowaves makes a set of 38dbi 5.8Ghz dishes. That would put the theoretical signal level at -65 or so with moderate cable loss. Was such great height necessary on both ends of the link? At 300 miles and 5.8Ghz it seems you only need a 160ft obstacle free fresnel zone. I'm stuck in pretty flat baghdad and paying a horrible amount for 10Mbps of satellite bandwidth each month. I have dreams of connecting out of country to somewhere with wired infrastructure, like Kuwait. A 200-300ft tower here is doable but not more. Any ideas, MT or otherwise?
tgrand
Long time Member
Long time Member
Wed Jan 17, 2007 5:57 am
As the post mentions... Earths curvature creates a mountain over long distances, which must be overcome.
This requires tall antenna support stuctures.
cmit
Wed Jan 17, 2007 11:33 am
If my in-head-calculator doesn't leave me, earth curvature alone will build a "mountain" of just over 4500 (!) meters for a distance of 300 miles (which should be about 480 kilometers)...
So for such a link you'll need REALLY big mountains on both sides to even ensure LOS. The clear fresnel zone shouldn't be a problem then anymore - it'll be about 80 meters fresnel radius for 5.6 GHz...
Best regards,
Christian Meis
afamnu
Wed Jan 17, 2007 8:27 pm
who's working on the same project in tripoli :d
bokad
Thu Jan 18, 2007 1:49 am
Wow, my bad! The calculator I was using was way out of whack on earth curve!
yakcora
Thu Mar 22, 2007 11:46 am
Tebrikler Kemal Bey... (TR)
God danged 240 KM and you were able to get those 35dbi antennas alligned.
I would get excited to see Cyprus from Tasucu when I was a kid.
Pictures please...
mcozio
Thu Mar 22, 2007 1:50 pm
and where is info about 5ghz insted of 2,4 ghz ? I am still waiting for it
doush
Long time Member
Long time Member
Thu May 03, 2007 6:45 pm
(/tur)
tebrikler kemal
biz g.magusa bolgesinde gNET WISP olarak 240km lik Wi-Fi linkinizi basariyla tamamlamanizdan dolayi sizi kutluyor, basarilarinizin devamini diliyorum.
(/eng)
Thanks kemal
As a small WISP in famagusta Cyprus, We congragulate your success on shooting a 240km link. good luck and best wishes.
Doush
http://www.gnetwireless.com
mkbatur
Sat May 12, 2007 9:23 pm
:lol:
bajingblack
Re: 240Km link with RB532 @ 20Mbits
Fri Jun 08, 2007 4:32 am
if i have radio with 200mw output and hyperlink 24 db grid antena in a both side how far i can link this stuff....thnks before......and wow salute for 240 km sucess link
boardman
Sun Jun 10, 2007 4:16 am
http://www.electro-comm.com/rfcalculations.html
dinfotec
Re:
Sun Jun 10, 2007 2:31 pm
Were are this link calculator? Please !
Regards,
Fran.
boardman
Sun Jun 10, 2007 5:18 pm
serthan
Thu Jul 19, 2007 11:35 am
Could you pls export the script of Links and share with us.
boardman
Fri Jul 20, 2007 2:12 am
MASTER:
/ interface ethernet
set ether1 name="ether1" mtu=1500 mac-address=00:0C:42:0A:6B:91 arp=enabled disable-running-check=yes auto-negotiation=yes \
full-duplex=yes cable-settings=default mdix-enable=yes speed=10Mbps comment="" disabled=no
set ether2 name="ether2" mtu=1500 mac-address=00:0C:42:0A:6B:92 arp=enabled disable-running-check=yes auto-negotiation=yes \
full-duplex=yes cable-settings=default speed=100Mbps comment="" disabled=no
set ether3 name="ether3" mtu=1500 mac-address=00:0C:42:0A:6B:93 arp=enabled disable-running-check=yes auto-negotiation=yes \
/ interface wireless
set wlan1 name="wlan1" mtu=1500 mac-address=00:15:6D:63:06:21 arp=enabled disable-running-check=no \
radio-name="00156D630621" mode=bridge ssid="Mirando Link" area="" frequency-mode=manual-txpower country="united \
states" antenna-gain=1 frequency=5220 band=5ghz scan-list=default rate-set=default \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007 \
ack-timeout=dynamic tx-power-mode=manual-table noise-floor-threshold=default periodic-calibration=default \
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic \
wds-default-bridge=wds-bridge wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no \
update-stats-interval=disabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 \
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default \
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment="" \
disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=yes enable-polling=yes framer-policy=dynamic-size framer-limit=3200
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:28,2Mbps:27,5.5Mbps:26,11Mbps:25,6Mbps:28,9Mbps:28,12Mbps:28,18Mbps:28,24Mbps:27,36Mbps:27\
,48Mbps:26,54Mbps:25
/ interface wireless security-profiles
set default name="default" mode=none authentication-types="" unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" \
wpa2-pre-shared-key="" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none \
static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none \
static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" \
radius-mac-authentication=no group-key-update=5m
/ interface wireless wds
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=yes audio-monitor=00:00:00:00:00:00 filter-mac=00:15:6D:63:06:48 \
ssid-all=yes frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless access-list
add mac-address=00:15:6D:63:06:48 interface=wlan1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 \
private-algo=none private-key="" comment="" disabled=no
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name="" file-limit=10 \
streaming-enabled=no streaming-server=0.0.0.0 streaming-max-rate=0
/ interface bridge
add name="wds-bridge" mtu=1500 arp=enabled stp=no priority=32768 ageing-time=5m forward-delay=15s \
garbage-collection-interval=5s hello-time=2s max-message-age=20s comment="" disabled=no
/ interface bridge port
add interface=ether1 bridge=wds-bridge priority=128 path-cost=10 comment="" disabled=no
add interface=wlan1 bridge=wds-bridge priority=128 path-cost=10 comment="" disabled=no
/ ip ipsec proposal
add name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024 disabled=no
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
/ ip upnp
set enabled=no allow-disable-external-interface=yes show-dummy-rule=yes
/ ip arp
/ ip socks
set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns
set primary-dns=0.0.0.0 secondary-dns=0.0.0.0 allow-remote-requests=no cache-size=2048KiB cache-max-ttl=1w
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m inactive-flow-timeout=15s
/ ip address
add address=10.10.100.234/24 network=10.10.100.0 broadcast=10.10.100.255 interface=ether1 comment="" disabled=no
/ ip proxy
set enabled=no port=8080 parent-proxy=0.0.0.0:0 maximal-client-connecions=1000 maximal-server-connectons=1000
/ ip proxy access
add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" disabled=no
/ ip accounting
set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set wlan1 discover=yes
set wds-bridge discover=yes
/ ip route
add dst-address=0.0.0.0/0 gateway=10.10.100.254 scope=255 target-scope=10 comment="" disabled=no
/ ip firewall service-port
set ftp ports=21 disabled=no
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set gre disabled=yes
set pptp disabled=yes
/ ip firewall connection tracking
set enabled=no tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s \
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m tcp-syncookie=no
/ ip hotspot service-port
/ ip hotspot profile
set default name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 \
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
/ ip hotspot user profile
set default name="default" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1 \
transparent-proxy=yes open-status-page=always advertise=no
/ system logging
add topics=info prefix="" action=memory disabled=no
add topics=error prefix="" action=memory disabled=no
add topics=warning prefix="" action=memory disabled=no
add topics=critical prefix="" action=echo disabled=no
add topics=wireless prefix="" action=memory disabled=no
add topics=system prefix="" action=memory disabled=no
/ system logging action
set memory name="memory" target=memory memory-lines=100 memory-stop-on-full=no
set disk name="disk" target=disk disk-lines=100 disk-stop-on-full=no
set echo name="echo" target=echo remember=yes
set remote name="remote" target=remote remote=0.0.0.0:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 check-interval=1d user=""
/ system clock manual
set time-zone=+00:00 dst-delta=+00:00 dst-start="jan/01/1970 00:00:00" dst-end="jan/01/1970 00:00:00"
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes no-ping-delay=5m automatic-supout=yes auto-send-supout=no
/ system console
add port=serial0 term="" disabled=no
/ system identity
set name="Master PtP APL to MIrando"
/ system note
set show-at-login=yes note=""
/ system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet enter-setup-on=any-key cpu-mode=power-save \
memory-test=no cpu-frequency=333MHz boot-protocol=bootp enable-jumper-reset=yes
/ system ntp server
set enabled=no broadcast=no multicast=no manycast=yes
/ system ntp client
set enabled=yes mode=unicast primary-ntp=10.10.100.254 secondary-ntp=207.46.130.100
/ port
set serial0 name="serial0" baud-rate=auto data-bits=8 parity=none stop-bits=1 flow-control=hardware
/ queue type
set default name="default" kind=pfifo pfifo-limit=50
set ethernet-default name="ethernet-default" kind=pfifo pfifo-limit=50
set wireless-default name="wireless-default" kind=sfq sfq-perturb=5 sfq-allot=1514
set synchronous-default name="synchronous-default" kind=red red-limit=60 red-min-threshold=10 red-max-threshold=50 \
red-burst=20 red-avg-packet=1000
set hotspot-default name="hotspot-default" kind=sfq sfq-perturb=5 sfq-allot=1514
add name="default-small" kind=pfifo pfifo-limit=10
/ queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set wlan1 queue=wireless-default
set wds-bridge queue=default
set wds1 queue=wireless-default
/ user
add name="admin" group=full address=0.0.0.0/0 comment="system default user" disabled=no
/ user group
add name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,!ftp,!write,!policy
add name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,!ftp,!policy
add name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ radius incoming
set accept=no port=1700
/ snmp
set enabled=yes contact="xxxx" location="APL Tower"
/ snmp community
set public name="xxxx" address=0.0.0.0/0 read-access=yes
/ tool bandwidth-server
set enabled=yes authenticate=yes allocate-udp-ports-from=2000 max-sessions=10
/ tool mac-server ping
set enabled=yes
/ tool e-mail
set server=0.0.0.0 from="<>"
/ tool sniffer
set interface=all only-headers=no memory-limit=10 file-name="" file-limit=10 streaming-enabled=no streaming-server=0.0.0.0 \
filter-stream=yes filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535
/ tool graphing
set store-every=5min
/ routing ospf
set router-id=0.0.0.0 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no \
redistribute-bgp=no metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=20
/ routing ospf area
set backbone area-id=0.0.0.0 type=default translator-role=translate-candidate authentication=none prefix-list-import="" \
prefix-list-export="" disabled=no
/ routing bgp
set enabled=no as=1 router-id=0.0.0.0 redistribute-static=no redistribute-connected=no redistribute-rip=no \
redistribute-ospf=no
/ routing rip
set redistribute-static=no redistribute-connected=no redistribute-ospf=no redistribute-bgp=no metric-static=1 \
metric-connected=1 metric-ospf=1 metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
SLAVE:
set ether1 name="ether1" mtu=1500 mac-address=00:0C:42:0A:6B:8E arp=enabled disable-running-check=yes auto-negotiation=yes \
full-duplex=yes cable-settings=default mdix-enable=yes speed=100Mbps comment="" disabled=no
set ether2 name="ether2" mtu=1500 mac-address=00:0C:42:0A:6B:8F arp=enabled disable-running-check=yes auto-negotiation=yes \
set ether3 name="ether3" mtu=1500 mac-address=00:0C:42:0A:6B:90 arp=enabled disable-running-check=yes auto-negotiation=yes \
set wlan1 name="wlan1" mtu=1500 mac-address=00:15:6D:63:06:48 arp=enabled disable-running-check=no \
radio-name="00156D630648" mode=station-wds ssid="Mirando Link" area="" frequency-mode=manual-txpower country=united states \
antenna-gain=0 frequency=5120 band=5ghz scan-list=default rate-set=default \
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled \
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled \
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 \
proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s \
on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment="" disabled=no
set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no \
/ interface bridge
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2 keepalive-timeout=30 \
/ ip ipsec proposal
/ ip service
/ ip upnp
/ ip arp
/ ip socks
/ ip dns
/ ip traffic-flow
/ ip address
add address=10.10.100.235/24 network=10.10.100.0 broadcast=10.10.100.255 interface=ether1 comment="" disabled=no
/ ip proxy
/ ip proxy access
/ ip accounting
/ ip route
/ system logging
/ system watchdog
/ system console
/ system identity
set name="Slave PtP APL to Mirando"
/ system note
memory-test=no cpu-frequency=399MHz boot-protocol=bootp enable-jumper-reset=yes
/ system ntp server
/ system ntp client
/ port
/ ppp profile
set default name="default" use-compression=default use-vj-compression=default use-encryption=default only-one=default \
change-tcp-mss=yes comment=""
set default-encryption name="default-encryption" use-compression=default use-vj-compression=default use-encryption=yes \
only-one=default change-tcp-mss=yes comment=""
/ ppp aaa
/ queue type
/ queue interface
/ user
/ user group
/ user aaa
/ radius incoming
/ snmp
set enabled=yes contact="xxxxx" location="Mirando Tower"
/ snmp community
set public name="xxxxx" address=0.0.0.0/0 read-access=yes
set enabled=yes
/ tool e-mail
/ tool sniffer
/ tool graphing
/ routing ospf
/ routing ospf area
/ routing bgp
/ routing rip
CHEERS....
Jorge
channingzou
Fri Jul 20, 2007 7:17 am
It make people more interesting with RouterOS ,but both sides at more than 800 meters above the sea level may not work any where,well unreasonable.
normis
Fri Jul 20, 2007 9:00 am
why not? see, it works for these people.
JR
Fri Jul 20, 2007 11:52 pm
is it 2.4 or 5GHz?
poster has "p2p link 5ghz" then "sr2 for 2.4ghz" and "i send 5ghz result"
then there's a config with "frequency=5220"
boardman
Sat Jul 21, 2007 3:54 am
is it 2.4 or 5GHz?
Check the config of the MASTER side, "frequency=5220 band=5ghz" the slave radio self-adjust to MASTER frequency.
Best
Jorge Boardman
GWISA-Kroonstad
Thu Aug 23, 2007 3:07 pm
Got a request from Omar in Tripoli, Lebanon... Needs internet connectivity and Looking for an ISP. I am Lebanese, but unfortuantely can't help coz I live in South Africa. Anyone can help Omar with internet services? His email is <o_Hawchar@hotmail.com. Thx.
doush
Long time Member
Long time Member
Fri Oct 12, 2007 3:48 pm
Although if this is the link that I have seen on top of the tower in cyprus montains, it is 2W amplified.
oz_gr
Sat Oct 13, 2007 6:58 pm
which tower & and which mountain ? ! well in a free area i would also prefer to use amps! wouldnt you :=)?
doush
Long time Member
Long time Member
Sun Oct 14, 2007 1:37 pm
Ofcourse.. just gave the info to have a better understanding of the achievied link. Its still a success...
skynoc
Sun Oct 21, 2007 10:59 pm
hello
i have tested this link here in lebanon , you cant use it in a sunny day .
skynoc
Sun Oct 21, 2007 11:00 pm
sr2 cant work on 5 ghz , so what cards did you use ?
hchady
Sun Nov 11, 2007 4:31 pm
hello
where in lebanon ? we are a small WISP in north lebanon using also MT and we are searching for a such link from cyprus
Any suggestions ?
skynoc
Sun Nov 11, 2007 11:29 pm
we are waiting our E1 from the ministry of telecom .We are going to be the first ISP in the North ,
Skynoc
Technical manager
+96170167093
+9616208205
SAT-ISP
hchady
Mon Nov 12, 2007 12:59 am
and what about the link from cyprus ? any other news ?
Where are you located in north lebanon ? we are actually in Kobayat (Akkar)
skynoc
Mon Nov 12, 2007 1:05 am
we are in Tripoli el Mina ,i said before that we tested this link and many problems were faced because of the interference .
the other end of the link was in AL Sayda in Ehden (1350 Meters)
delay to google was pretty good but we faced disconnection each ~30 minutes
skynoc
tully
Tue Nov 13, 2007 4:45 pm
You should send a supout file from each router to support@mikrotik.com with a description of the equipment.
John
maximo64
Fri Nov 30, 2007 10:06 pm
Congratulations, very good job !
Here is a very good Link analysis calculator:
http://my.athenet.net/~multiplx/cgi-bin ... s.main.cgi
Using this and all the rest of the data posted for 5ghz I obtained an Unfaded Free space received power level of -62.61 dBm. Very Good signal, as others mentioned the trick is antenna heights, however this may be the case for many geographical situations.
debfam
Thu Jan 10, 2008 4:16 pm
I would be very happy if you can send me the setup I would like to learn more only my area is a hilly area.
Also which frequency is good for long distance link
my email is debfam@gmail.com
Thank you
sarpkaya
Wed Apr 09, 2008 4:35 am
I've got a question for you, how do you set these antennas see each other in a clear line? I heard somewhere that we should use GPS, but I wondered what did you used Kemal Bey? and what's your company name?
alex_rhys-hurn
Fri Apr 25, 2008 1:07 am
I have used 30dbi antennas and the best trick I could work out was this:
Make a long (like 1.5 meter) T shaped wooden bracket, that can hook over the front of the antenna. This works great for panel and dish antennae. Yagis you can point any way.
You then hook (somehow, you have to be creative for this part now) your wooden pointer on to your antenna.
This now acts as a pointer that you can use to sight along in order to direct the antenna the right way. you can put a spirit level in it to ensure the antenna is level or set to whatever downtilt you need.
Now, you must point this at a landmark that you have recorded earlier with a compass to get a bearing.
For this you need GPS, Compass, Google Earth.
I suggest you read about taking a bearing in any good marine navigation training guide.
Good Luck.
Alex
FNC
Thu Oct 30, 2008 1:33 pm
Is this link Still Working?
twana222
Thu Nov 13, 2008 2:33 pm
good job, but should be no interference in there, cause when you have interference it is gonna be weaker. :lol:
samsoum
Thu May 27, 2010 7:51 pm
HI
iam interested to build a link over sea around 270km
can any body help building such link.
the link is between cyprus and lebanon.
doush
Long time Member
Long time Member
Sat May 29, 2010 11:28 am
@samsoum
shoot us an email
yalmandogus [at] yahoo.com
samsoum
Tue Jun 08, 2010 9:31 pm
hi
any body can help to build a link of 250km over sea 2.4 or 5gh
ready for any proposal.
pls send email if interested
sam@citycellhotspot.com
vladimirslk
Sun Jun 27, 2010 2:08 am
it'll be real to build from Anamur.... oorrrr if' it's possible to use 3+m antennas @ height ~50-75m... :)
landysaccount
Sun Jun 27, 2010 6:14 pm
Great job!
What type/brand radios are used in this link?
Users browsing this forum: No registered users and 46 guests
