MUM Europe 2020
devrim
Nstreme2 Question?
Sat Nov 11, 2006 8:26 pm
I am tried to understand how Nstrame2 operate...
http://www.mikrotik.com/testdocs/ros/2. ... #4.13.21.5
Have explanation how to configure Nstreme2.
But also i read some treat that say you can't use Nstreme2 with WDS!
So my question is If we have two RB532(Assume name A & B) and configure Nstreme2 as detailed above. Set A lan interface ip 10.0.0.1 and B lan interface ip to 10.0.0.2 this is enough to communicate from A to B or oposite way?
As i understand in Nstreme2 setup we must use two wlan interface and i think its not possible to group 3 interface together(Wlan1, Wlan2 & Lan0) . Or its possible to bridge nstreme interface to lan?
Thanks for your reply..
devrim
Equis
Forum Veteran
Forum Veteran
Sun Nov 12, 2006 10:21 am
I don't think wds (AP - AP) will work
AP- Station WDS will work (I think)
Id recommend using l2tp with eiop over the top (see manual)
devrim
Sun Nov 12, 2006 12:04 pm
Thanks Equis,
But as you know EoIP need ip in both point..
I must explain my situation more deep..
Let consider system configuration like below.
________ A ____________________ B ____________
LAN->| Mt Server | <--Nstreme2--->| Mt Client|->LAN
As you know Nstreme2 use two Wlan interface to communication. One of them used as Transmit and another to Receive.
I want to set A side Lan address 10.0.0.1
I want to set B side Lan address 10.0.0.2
There are 3 interface use in communication(Lan,Wlan1 and Wlan2) . Its not possible to group interfaces in bridge.
So how to know MT A access MT B over Nstreme?
Do i need aditional config for this situation? Proxy-arp or another thing?
Is it possible to bridge Nstreme2 interface with Lan interface?
Thanks..
devrim
Ps: At this time our devices not arrived. Teorically i tried to understand operation. Sorry if this questions are dummy.
Users browsing this forum: No registered users and 27 guests
