MUM Europe 2020
mbfound
N vs AC
Sun Apr 09, 2017 3:04 am
Hi all,
Quick question for the more experienced.
We're in the process of modernising our network and that means AC devices.
I've been fine tuning a few links, and usually just by switching to 'only-N/ A/N' I get more throughput or more stability.
Best example is a >10km link with Dynadishes, with AC 40mhz I get a bouncy 140Mbps and just switching to N throughput jumps to a stable 160Mbps. No frequency change.
Is this something you have seen as well? Do you think I'm nuts? Elaborate below.
mb
soulflyhigh
Re: N vs AC
Sun Apr 09, 2017 3:49 pm
To really be more spectral efficient, 802.11ac gear has to work in a lower-noise-level environment compared to 802.11n.
You can either try to find a cleaner channel or invest in higher gain antennas to achieve higher SNR.
Here is similar discussion > viewtopic.php?f=7&t=112525&p=558923#p558923
Regards,
M.
MTCRE, MTCTCE
mbfound
Re: N vs AC
Sun Apr 09, 2017 11:25 pm
Regards,
M.
Interesting, I'll give it a read. We aren't really in high noise environment since it's pretty rural. Most of the links are already on 30dbm dishes.
Users browsing this forum: Google [Bot], MSN [Bot] and 32 guests
