yegle
Failed to join CAPsMAN (CAP lost connection, send timeout)
Mon May 01, 2017 9:17 am
Hi list,
First post here, so forgive me if anything is missing or unclear to you.
Some context: I brought 3 WAP ac (G-5HacT2HnD) to be used as CAP, and a 951G-2HnD as manager. Two of the 3 WAP ac successfully joined the manager and everything is fine, but one shows a weird symptom that just refuse to join the manager. I've tried to reset this particular device multiple times but was still unable to get it working. I even wonder if this is a defect product and will need to RMA it.
I copied the debug log, along with the relevant configs below. Both the manager and the CAPs are in 6.39 (the latest version). Any help would be appreciated, thank you!
apr/30 23:04:19 caps,debug CAP Sulking->Discover
apr/30 23:04:19 caps,debug CAP discovery target list:
apr/30 23:04:22 caps,debug CAP discovery over, results:
apr/30 23:04:22 caps,debug   951G2HnD (::ffff:XXX.XXX.XXX.XXX:5246)
apr/30 23:04:22 caps,debug   951G2HnD (XX:XX:XX:XX:XX:XX/3/0)
apr/30 23:04:22 caps,debug CAP Discover->Select
apr/30 23:04:22 caps,info CAP selected CAPsMAN 951G2HnD (XX:XX:XX:XX:XX:XX/3/0)
apr/30 23:04:22 caps,debug CAP Select->Connect
apr/30 23:04:22 caps,info CAP connected to 951G2HnD (XX:XX:XX:XX:XX:XX/3/0), CommonName 'CAPsMAN-XXXXXXXXXXXX'
apr/30 23:04:22 caps,debug CAP Connect->Join
apr/30 23:04:31 caps,debug CAP lost connection, send timeout
apr/30 23:04:31 caps,info CAP failed to join 951G2HnD (XX:XX:XX:XX:XX:XX/3/0)
apr/30 23:04:31 caps,debug CAP Join->Select
apr/30 23:04:31 caps,info CAP selected CAPsMAN 951G2HnD (::ffff:XXX.XXX.XXX.XXX:5246)
apr/30 23:04:31 caps,debug CAP Select->Connect
apr/30 23:04:31 caps,info CAP connected to 951G2HnD (::ffff:XXX.XXX.XXX.XXX:5246), CommonName 'CAPsMAN-XXXXXXXXXXXX'
apr/30 23:04:31 caps,debug CAP Connect->Join
apr/30 23:04:40 caps,debug CAP lost connection, send timeout
apr/30 23:04:40 caps,info CAP failed to join 951G2HnD (::ffff:XXX.XXX.XXX.XXX:5246)
apr/30 23:04:40 caps,debug CAP Join->Select
apr/30 23:04:40 caps,debug CAP did not find suitable CAPsMAN
apr/30 23:04:40 caps,debug CAP Select->Sulking
CAP config:
/interface wireless cap export
set certificate=request discovery-interfaces=ether1 enabled=yes interfaces=\
    wlan1,wlan2 lock-to-caps-man=yes
CAPsMAN config:
/caps-man channel
add band=5ghz-a/n/ac name=5ghz-channel
add band=2ghz-b/g/n name=2ghz-channel
/caps-man datapath
add bridge=bridge-local local-forwarding=yes name=default
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=default passphrase=XXXXXXXXXXXX
/caps-man configuration
add channel=5ghz-channel country="united states" datapath=default mode=ap name=\
    5ghz-default security=default ssid=XXXXXXXXXXXX
add channel=2ghz-channel country="united states" datapath=default mode=ap name=\
    2ghz-default security=default ssid=XXXXXXXXXXXX
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes upgrade-policy=\
    suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
    5ghz-default name-format=identity
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
    2ghz-default name-format=identity
yegle
Re: Failed to join CAPsMAN (CAP lost connection, send timeout)
Sat May 06, 2017 10:18 am
Bump.
Still no clue and I have to disconnect the problematic one since it generates a huge heat compare to the other two devices (probably due to the excessive retry in joining CAPS-MAN).
Olytitor
Tue May 16, 2017 5:06 am
You changed the settings capsman > interface??? Check!
anuser
Long time Member
Long time Member
Thu Dec 14, 2017 2:25 pm
Did you find a solution?
flayerfilliper58
Mon Aug 27, 2018 3:23 pm
Not sure if that's your case but I had similar log entries when the cause was simply bad signal, which is very likely if you're using 2.4GHz. Wireless clients don't like to switch to a new AP if the one they're already connected to is at all visible, even if the signal strength is really bad.
In my case something like this helped:
/caps-man access-list
add action=accept interface=any signal-range=-80..120
add action=reject interface=any signal-range=-120..-81
Basically, kick off anything with signal below -80, so the client would connect to a closer AP with better signal. You might need to adjust the threshold based on your situation.
sujirou
Wed Nov 07, 2018 10:24 am
for some reasons, RouterOS craps out on this one especially when there are automation scripts. you can see on "system > scripts > Jobs" that the window if flooded with entries. this gets fixed by rebooting the router.
yegle
Wed Nov 07, 2018 7:12 pm
In case someone find this post:
I left that particular wAP ac out and just used the other two. Months later when I do need to use an additional AP, I connected it and updated the ROS version. Lo and behold it's working just fine now.
Still don't know what went wrong.
SeparateReality
Sun Jan 24, 2021 9:07 pm
This is quite old but I had the same situation and finally found out what was wrong (in my case).
My Cap was also set to certificate=request and after a while I found out that this was causing the issue.
Looking at the detailed Caps Log on the CAPsMan it showed that the CAPsMan could not generate a certificate for the Cap because it already existed. Thats because I used this Cap before in a different setup.
The solution was simply to revoke the existing certificate. The CAPsMan then just issued a new certificate for the Caps and everything went smooth from then on.
Users browsing this forum: Matta and 33 guests
