MUM Europe 2020
stuka
RB951g-2nd + e3372 (hilink and no hilink) loose connection when downloading something
Tue May 30, 2017 9:53 am
Dear All
I configured ( on RB951g-2nd + e3372 (hilink and no hilink) - test both )
ppp connection, i have internet , but when i start downloading something big around 500mb mikrotik brake's connection
when i reboot it (or remove power from mikrotik and connect it again) everything working good again till i start downloading again...testeed with hilink and with no hilink version , on hilink version when i try dowloading something and mikrotik brake connection i canot ping hilink gateway (software on mikrotik are : 6.39.1. modems are tested on laptop and working good , also tested with other mikrotik (rb951 normal version not 1Gbit ) and also working fine
Also tested with default configuration (restore to default setting's - still this same issue - braking connection after downloading something .
please let me know what i can do
Arek
dschn
Re: RB951g-2nd + e3372 (hilink and no hilink) loose connection when downloading something
Tue Aug 08, 2017 12:22 pm
I have the same problem: when there is some load on the stick it sometimes disconnects and won't reconnect unless the router is rebooted. Is there any fix for this issue? I put (rather: hacked) the E3372 in LTE mode (as some reports indicate that issue persists in PPP mode only), but to no avail :(
pe1chl
Tue Aug 08, 2017 3:44 pm
I think it depends on the power requirement of the LTE stick.
The router probably has not enough power supply capacity to supply the stick at full power.
Some people have reported better results when using a separate powered USB hub.
I have never tested that, but I have seen those interruptions as well. However, we use the LTE only as
a fallback link when the normal internet connection fails, sp it rarely is a problem here.
antonsb
Sun Aug 13, 2017 8:01 pm
Hello, please upgrade to latest RC version, there are some fixes regwrding this issue.
b3h3m07h
Tue Aug 15, 2017 1:00 pm
i am also having the a similar issue with a rb2011uas-2hnd and a e3372h-607. after downloading a few files for a minute or so the connection drops and router reboots. i am using the latest 6.41rc11 and have even tried the 5v usb power injector https://shop.duxtel.com.au/product_info ... cts_id=105 but still have issues.
any ideas on what i can try now?
dschn
Sun Oct 01, 2017 5:31 pm
I too have this issue and tried the latest RC, but to no avail. I have the very same problem with the E8372 stick. When there will be a fix for this problem? Or is there any workaround for it?
d3m2k4
Thu Oct 26, 2017 3:19 pm
I have same problem with e3372 and RB2011UiAS-2HnD-IN. Any solution?
haik01
Fri Oct 27, 2017 12:12 am
Anyone tried to use it with an external powered USB hub?
Of course, a lot of people use it as a "backup" line, which is correct. Only when "shit happens" (for example, a dog started to make a hole in the ground to hide the bone, and hit the fibre under ground, and bit the cable to pieces).....
So now in stead of 250 Mbit, you bow have a "poor" 5 Mbit over LTE (do not forget, that all other people in the neighbourhood also will fall back to LTE, since the fibre provided connectivity to the entire city area).
And THAT is the case, when a lot of data will be transferred over the LTE stick, and then it disconnects. Exactly (!) at the time when you really need it.
irghost
Fri Oct 27, 2017 1:14 am
Use USB Power injector
https://mikrotik.com/product/5VUSB
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
d3m2k4
Mon Nov 13, 2017 10:14 am
Confirmed, it does not work, the problem still occurs!
Users browsing this forum: Lupin and 20 guests
