sina62ir
SXT LTE lost lte interface
Tue Jul 18, 2017 3:15 pm
Hi
I have a SXT LTE.
The lte interface of router has removed.
sometime be correct by reboot,but sometime had to install lte package.
why?
router os version is 6.38.7 bugfix
irghost
Re: SXT LTE lost lte interface
Tue Jul 18, 2017 3:43 pm
you must install lte package
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
nikc
Tue Jul 18, 2017 3:51 pm
Hi
I have a SXT LTE.
why?
I have the same issue with the LTE interface disappearing ... it happens under high load (maxing the LTE connection) and I can recreate it all the time.
Its a real PITA.
sina62ir
Wed Jul 19, 2017 10:36 am
install package is not good idea.because every day I have to install LTE package again.
I had 30cuncurent User. not more
​​"Sina BagherpourTahmtan"
MikroTik Trainer #TR0454
IT manager of "BamaIT co"
www.BamaIT.net
mobile: 09176933677
normis
Wed Jul 19, 2017 10:44 am
This issue is fixed in 6.39 and newer (current and RC branches)
sina62ir
Wed Jul 19, 2017 10:46 am
tanks normis.
www.BamaIT.net
mobile: 09176933677
nikc
Wed Jul 19, 2017 12:20 pm
Do you mean the issue with the interface dropping under high load or ?
I am on latest build and can still reproduce this everytime :(
https://www.dropbox.com/s/87s3p9pl2y7lm ... 6.mp4?dl=0
normis
Wed Jul 19, 2017 12:23 pm
Yes, it looks like the specific issue sometimes happens on this particular product, we are looking into it. It looks like other LTE modems and wAP LTE does not have this issue. The problem on SXT LTE takes place under heavy UDP traffic, but we are still investigating.
nikc
Wed Jul 19, 2017 12:27 pm
Is there something I can do to assist ? I've sold / implemented maybe 10 of these now as we are pretty rural and its our only option. The problem happens on all of the devices, in a small home environment its not so bad, but I have some larger customers also who are starting to get upset with the stability problems this is causing.
Nik
normis
Wed Jul 19, 2017 12:31 pm
Initial suspicion is that this is a problem in the driver, so we are working with the chipset manufacturer to investigate. It seems that if you need a quick fix, the wAP LTE or some other hardware replacement (we have several devices that support miniPCIe LTE modems) is the quickest fix for the important locations. Testing department says that no other LTE device (that we make/sell) has this issue in RouterOS.
nikc
Wed Jul 19, 2017 12:33 pm
Thanks for the reply, I'm afraid the cost of revisiting the sites and getting up on the roofs to replace kit would make this a loss for me so I will have to wait for the fix.
pukkita
Trainer
Trainer
Wed Jul 19, 2017 3:03 pm
Just an idea, maybe rate-limiting UDP you can alleviate the issue in the meanwhile...
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
AkaZLOY
Mon Aug 07, 2017 3:48 am
Same problem at 6.38.7 (bug fix only).
I tried install 6.40.1, but lte interface didn't appear. Any ideas about optimal version of RoS or fix this problem?
nikc
Mon Aug 07, 2017 12:45 pm
+1 for an update on this please.
AkaZLOY
Wed Aug 09, 2017 3:12 am
A little bit help dns flood block, since Interface has not yet down.
/ip firewall raw
add action=add-src-to-address-list address-list="dns flood" address-list-timeout=1d chain=\prerouting dst-port=53 in-interface=lte1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=lte1 protocol=udp src-address-list="dns flood"
Resnais
Wed Aug 16, 2017 10:31 am
Im on my third SXT LTE (exchanged two times within warranty), and it does not hang up or loose the lte interface anymore (even on high loads 50+ Mbit/s for hours). In my SXT Lte's I always used the latest ROS release candidate and Routerboard fw version.
So, in my opinion, it is worth replacing the device within warranty.
The only complaint i have now- latency. My phone (LTE), laptop(LTE) ping in speedtest shows about 15ms. SXT LTE which is outside the building, with better signal conditions has never shown me better ping than 19ms (on all three SXT LTE's i had). I hope the UDP flood problem, @Normis is talking about, is somehow releated to this.
Good luck,
Resnais
Dewaal
Thu Jan 11, 2018 3:59 pm
Hallo!
I've got 17 of sxt lte devices in the field, and would love to have a short term solution to this issue.
Is it possible to have the below IF statement within "netwatch"? Need a bit of help with the coding if possible.
Netwatch: action if link is down -
IF LTE is not on/'showing under interfaces' [#Check if LTE is under interfaces]
/reboot
ELSE
/disable LTE1
:delay 5s
/enable LTE1 [#to try and reset LTE connection]
Thanks in advance!
sebastia
Sat Jan 27, 2018 11:15 pm
Hi
Considering a purchase and wondering if this is still an issue?
MaxMeindl
Mon Feb 05, 2018 8:20 am
Hi Mikrotik
Any news on the above issue. I have about 40 installed, and this issue happens on around 15 of the 40, almost daily.
All on the latest firmware.
Please help. I have looked into getting a wapLTe device but there is no stock in South Africa it seems for a month.
odonaghue
Wed Mar 21, 2018 1:21 am
Hi, I am seeing the same issue. Has anyone else had thus issue, i have installed the newest upgrade to the software but no joy.
hkaiser
Tue Mar 27, 2018 8:24 pm
Hi i have the same problem on ROS 6.41.2, so when this problem will be solved?
nur
Thu Mar 29, 2018 8:17 pm
Hello, how to connect to vpn server by using SXT LTE? I was tried to create connection with my vpn server but the connection wasn't establish but when i using RB the connection can establish. I was using VPN L2TP with IPSec. Any idea?
njmsa
Tue Oct 23, 2018 12:12 pm
Hi, I'm getting the same issue (connection randomly drops and doesn't reconnect - I then have to power cycle the router to get it up and running again) with the new RBSXTR&R11e-LTE running version 6.43.2 software. Please tell me there's a solution to this as it is really embarrassing and difficult to explain to a client.
helmi1987
Sun Dec 02, 2018 11:05 am
i have make a schedule with this command start all 5 Minutes
:if ([:len [/interface find name="lte1"]] = 0) do={[/log error "LTE not found"] & [/system reboot]} else={[/log info "LTE-Found"]};
i hope this will help for a workaround
my RouterOS version is 6.43.4
elpaso
Fri Dec 14, 2018 10:38 am
<t>In my case SXT LTE kit (RBSXTR&R11e-LTE) lte INTERFACE DOES NOT MISS. The antenna stops working with the 4G network (BAND 20), and this can happen even 3 days after a complete reset, or maybe 2 weeks later, refuse to register on the network. In the settings it works with 3G / 4G. It does not register itself in 3G. LTE interface does not disappear. Turning off / enabling LTE interface does not give anything. Very disappointed. If someone else behaves like the device, please write how you solved this problem Version 6.43.7 firmware</t>
ccoleman831
Sat Jan 12, 2019 2:48 am
Anyone get a fix for this? have around half of my installs with this problem some worse than others
beh0ld
Thu Feb 28, 2019 2:47 pm
I have same issue, downgrade routeros or reinstal package lte didnt help.
ccoleman831
Tue Jun 04, 2019 11:55 am
Hi Mikrotiks, any fix for this yet? Still happening on several units on a daily basis others weekly?
robpeng
Thu Jun 06, 2019 5:58 pm
Hi Mikrotik guys,
Is the LHG LTE kit (https://mikrotik.com/product/lhg_lte_kit) safe from the LTE modem/firmware issues listed above?
Cheers,
Rob
sebastia
Tue Jun 11, 2019 4:39 pm
It's same modem but different antenna...
robpeng
Tue Jun 11, 2019 4:51 pm
Doing some more testing, I don't see my LTE interface disappearing but I do have a lot of disconnects during quiet times in my network. Its like my operator disconnects when there is no activity.
I have a ping 1.1.1.1 script scheduled which restarts the interface on-failure, works pretty well too.
My STX LTE units are the newer ones as they don't have the lte package installed so maybe this is why I don't see the interface disappearing. I sometimes do a usb power reset (kills power to LTE chip) and the interface disappears for a few seconds
Resnais
Thu Aug 29, 2019 9:22 am
Looks like 2 years later we still have new fixes regarding the problem: ROS version 6.45.5 changelog- lte - fixed LTE interface disappearing on RBSXTLTE3-7;
Maybe someone who's still standing tall with RB SXT LTE 3-7 could post something- any changes with 6.45.5?
hersawex
Tue Sep 10, 2019 11:14 am
Yeah, reporting in. My RB SXT LTE still suffer intermittent no connectivity. Currently running 6.45.5 for about 1d plus. My case was not LTE interface disappear but more to LTE interface just "hang" and no connectivity at. I have a script written to ping google dns, and if they ping fail for 15 times, reset the Interface. The script will repeat itself every 3 minutes. In short, 6.45.5 didn't fix my problem and this is very annoying especially when I am playing online gaming.
#mikrotikpleasefixtherproblem
CoolTom
Sun Sep 22, 2019 3:11 pm
Happening similar stuff. After few days LTE modem freeze and it just say in status tab: pin status: unknown. LTE interface not disapear.
I tryed:
USB reset
device restart using restart
device restart power disconnect
AT command /interface lte at-chat lte1 input="AT+reset"
change slot A to B and back.
I have last stable and last FW for modem: MikroTik_CP_2.160.000_v012
stable version upgraded to: 6.45.6
ONLY THINK WHAT HELPS IS REMOVE SIM AND INSERT IN BACK. than its just start working normaly.
Imagine always go to the roof and do it.
So not even desable/enable/reset script help for me.
any slolution or should i return device?
CoolTom
Sat Oct 12, 2019 1:13 pm
I installed last stable OS v6.45.6 and it seems to be fine now. Now its on for 3 weeks ...
Seems like for "new" Mikrtoik devices (4011, 60G, LTEs) is better use last stable instead of long term ....
ksthree
Wed Nov 20, 2019 5:48 pm
I have three SXT LTE units in the field. I have made more than 20 trips trying to resolve these issues. I have found locking it to the strongest Band and to LTE reduces it, but not completely.
Today we have 2 of the radios losing LTE connectivity all together. This places in the log:
lte1: not registred, state: 0
and
lte1: not registred, state: 11
Where can we get a list of the state codes and what they mean?
I am a RouterOS Junkie... needing my daily fix. If I don't get to work on a RouterBoard I get a major itch.
b00ze
Tue Dec 31, 2019 10:18 am
Hi!
Can you tell please, have you any problems with SXT after upgrading to v6.45.6?
CoolTom
Thu Jan 02, 2020 11:52 am
Hi, sice my last post, there was one problem - when device power off and power on after 1 week. LTE doest connect. But I just disable LTE interface and re-enable it and it connect without problems. So lets say, yes it work much better then before. Before I had to remove sim and plug it back to be able "reset it" and make it connect to LTE ...
Now running on 6.45.7
Hi!
subdee
Wed Sep 30, 2020 2:00 pm
Why haven't I red this earlier. I would not bought it :( such a waste of money only frustration. I tried installing 6.48beta40 and LTE interface keeps disappearing and it been 3 years this issue exist.
Users browsing this forum: MulderSk and 44 guests
