jamies
What Devices
Mon Jul 31, 2017 5:52 pm
hi there,
we have to build a new wireless network I was thinking of using 2 RBMETALG-52SHPACN devices, one connects into the main router and acts as an Access Point and then the 2nd RBMETAL is further away and acts as a Repeater and Access Point is the RBMETALG-52SHPACN capable of doing this, bear in mind the 2nd RBMetal has to act as both repeater and AP, also the devices are outdoors or do i need one with 2 radios, if so what product do i need?
thanks
Jamie
Ibersystems
Re: What Devices
Wed Aug 02, 2017 6:38 pm
You can use that, it should work, but If you want to create a good service, you need to use something as "station" to receive signal and repeat in another frequency with that Aps.
I prefer to have devices for point to point and devices for multipoint. And try to avoid APs with 2 radios in same frequency.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
Users browsing this forum: No registered users and 24 guests
