man
Hotspot rx/tx rate limit does not work
Tue Aug 15, 2017 5:30 pm
Hello, have just configured Hotpost with the trial internet. And spend around 4 hours to set the upload and download limit for trial users to 512k
All my attempts are unsuccessful.
Have tried to create a User Profile with Rate Limit:512k/512k
Have added same limit at the Hotspot server profiles ....
All i get is an upload speed reduces to 512k but not the download ... looks like the setting for limitation of Download speed is ignored..
Any help is highly appreciated!
man
Re: Hotspot rx/tx rate limit does not work
Wed Aug 16, 2017 3:59 pm
After a few reboots of the router, it works ...
man
Wed Aug 16, 2017 4:28 pm
And again, without any changes only upload is limited and not a download ...
brunoeco
Fri Sep 15, 2017 10:15 pm
Same problem here with the RB951Ui-2nD.
Did you fixed it ?
Thor187
Sun Oct 22, 2017 1:37 am
Same issue - this is a bug in the Mikrotik software.
rickzmond
Sun Nov 19, 2017 6:23 pm
I have the same issue, but resolved it. I am using RB951Ui-2HnD. Running on latest 3.41 firmware and 6.40.5 RouterOS.
Reset the configuration, use winbox to log in. At the first startup screen. Remove configuration.
Manually configure all the interfaces ( DHCP, LAN, WAN, etc), create bridge for LAN and WIFI manually, NAT, and then setup the hotspot.
Users browsing this forum: No registered users and 20 guests
