MUM Europe 2020
nickb
How much load does WPA2 add?
Fri Dec 01, 2006 6:00 am
How much additional CPU time does WPA2 add to an AP? For example, I have an RB532 with Senao 2511MP for feed, SR2 for broadcast, and CM9 feeding another tower. Remote tower has 10 clients, this unit has 37 clients. When traffic is at it's heaviest on this AP, cpu usage in cacti shows around 17%. No encryption is in use at all on this AP, so I'm curious, if all the clients were WPA2, how much more CPU would that use?
Equis
Forum Veteran
Forum Veteran
Fri Dec 01, 2006 6:31 am
Doess wpa encr get done on the CM9 not the RB?
nickb
Fri Dec 01, 2006 11:02 am
There is some offloading, but as far as I know it's not done entirely by the card.
normis
Fri Dec 01, 2006 11:04 am
on CM9, the WPA is done entirely in the card. it should not affect CPU usage.
nickb
Sun Dec 03, 2006 1:00 am
I assume that the same would be true for the R52 then, since it is based on an even newer Atheros chip?
janisk
Mon Dec 04, 2006 12:32 pm
true
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
