randallr
RB14 4 port Mini-PCI w/ multiple R52 or SR5
Tue Dec 05, 2006 3:53 am
I've found the pwr requirements:
R52 400ma
SR5 1300ma
All I've found for the RB14 is:
"Up to 2.5w of 3.3v power supplied to Mini PCI card"
Anyone know if this is per slot, or total..
And also, my math is not my best ability.. is it
.4 x 3.3 = 1.32 watts?
1.3 x 3.3 = 4.29 watts?
If my math is correct, then doesn't look like I should put an SR5 in one...
Randall
sergejs
Tue Dec 05, 2006 10:16 am
per slot.
If you will look corrrectly, there is a note "Should not be used with SR5 or SR2 400mW miniPCI!".
You cannot use regular RB14 with 4 SR wireless cards, however you can use two SR wireless cards, plug them to the one side of the RB14, either RB14 might be damaged.
4 R52 or any other regular wireless cards might be used without any problems.
janisk
Tue Dec 05, 2006 10:19 am
you are correct, Wattage cannot exceed its limits or it may damage your hardware or it will malfunction.
Users browsing this forum: No registered users and 34 guests
